Tuning AV for Matsui 1414r
I have just bought a set top box for a Matsui 1414r TV but when I am on AV with the set top box on it's as if the AV channel needs tuning. The setup box that appears when i turn the set top box on whizzes all over the screen.
  • Anonymous Dec 09, 2008
    I have the same exact problem with the former poster. same TV.
  • 5 Answers
SOURCE: How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Posted on Sep 16, 2009
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
smeago1
  • 136 Answers
SOURCE: ps3 tuning
Hi Tom,
I hope I can assume that you have a relatively new TV. I will go through both scenarios.
If your TV supports hdmi cables then you should plug one end of the cable from the PS3 and the other end to your tv in the HDMI input. Make sure on your TV you go to menu - external inputs and navigate to the HDMI mode then you will be fine.
IF you are not using a HDMI cable, then I hope i can assume that you are using component (3 cables of red blue and yellow). Same principles these cables should go from your ps3 to your tv and select the appropriate AV input on your tv for it to work. Note if you are using component cables you will also need to plug the sound cable to your tv or via your receiver.
If you could provide me with more information on your tv model, if you are hooking up your ps3 via a receiver or not then i can help you more promptly.
Thanks
Smeags.
Posted on Jan 03, 2008
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
Posted on Oct 29, 2008
SOURCE: Lock code for Onida Black Dlx channel tunner menu
My Tv is locked and cannot start. it asks for password.
how to open it?
Posted on Mar 13, 2010
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
How to tune channels on an old RCA 14 inch tv?
The tuning is all done on the set top box. All you have to do is select AV channel of your TV, the same as when you selected the AV for the VCR's, if you still remember the days of old technology VCR's.
Sep 01, 2014 | Televison & Video
Matusi 1414r tuner locked
Try to download the user manual to your Matsui TF from net. I tried ot find it, but went in vein.
May 14, 2012 | Televison & Video
Just need to know hoiw to tune set top box to tv
I'll assume that you mean "CONNECT set top box to TV". Look at both devices for the options of physical connection. If both have an HDMI connection, choose that first. If HDMI is not an option, then see if component connection (5 RCA connectors: RGB+RW) is available. If both are not options, then see if AV is an option (3 RCA connectors: Y+RW). If you have a real dinosaur, then go with Coax and set the TV to channel 3 or 4. Now that the TV is connected to the set top box using the best available connection, program the set top box as required by that particular box. From now on, you'll only change channels with the set top box.
Jul 19, 2011 | Televison & Video
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
We bought a used AV-32D305. It didn't come with the remote. We hooked it up to cable our cable box and it worked fine for three days. Today we turned it on and there's was just a blue screen with the...
hi
well to bad it looks like you have a bad tuner
I would suggest to use your cable box if you have a remote or it and connect your cable box in video mode or use a vcr in the same maner
Sep 30, 2010 | JVC AV-32D305 32" TV
Matsui VP 9501 0P VCR - Digital TV ready?
The converter boxes can hook right up to any vcr on the antennae in jack. They work just the same. I like using vcrs because you can hook up anything to them and then run it to tv. It's great!
Nov 17, 2009 | Televison & Video
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
Electro Med Services...
