Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
Restarting PC after installing 2G (2x1G) ram...my computer keep restarting whenever reaching certain period of time..what's the problem?
  • lolo08 May 22, 2008
    I want to install xp on winsonic w sp4m8- pro motherboard, but the computer is restarting during installation
  • 871 Answers
Your motherboard may be experiencing compatibility issues with that memory youve jst installed. it will work for some time but when it starts to become unstable, it will restart, you have yo adjust the memory timings for that memory in BIOS.
Posted on Mar 18, 2008
    Novelist:
    Champion:
  • 236 Answers
If you just added another 1g to your ram and your trouble started, it could be the difference in memory operating speed. If both are new, either one of the memory module is defective.
Posted on Apr 08, 2008
    Genius:
  • 1,913 Answers
Hello
i think your your ram have different frequency.so restart system.
second check your power supply and earthing problem.check smps.scan your system with avast,quick heal,and symantec antivirus.my system also restart bcause of power cable pro.i think in your case most of the problem of ram or power supply
CPU will not recognize the last memory slot in my FX4710
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Jul 26, 2013 | Gateway FX4710-UB003A Core 2 Quad Q9300...
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
My computer will not boot up when 2 g ram
Try upgrading your Bios first, also make sure that the memory that you ar putting in your Laptop is type PC-2700. Other than this, I know that this comptuer has a 2G limit and should have no problem with it.
Sep 06, 2009 | Compaq Presario R3000 Notebook
T30 boot problem
Once again , bad ram will prevent your computer from booting , make sure you are using a known good ram module.
don001996
Mar 08, 2009 | IBM ThinkPad T30 2366 Notebook
Adding RAM
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
May 10, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Toshiba L100 equim memory update
Try this, get a pencil eraser and rub it on the copper portion of your memory ( 2gb ). insert it on the memory slot, power on your pc and go to the set up menu.( You can go to the set up menu by pressing F2 or delete key on your pc once it boots up ). and check if your system recognizes the RAM ( memory ) you inserted. Let me know if you have any other question.
A Simple Thanks is Good Enough
Feb 15, 2008 | Computers & Internet
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
87 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
