Toshiba Qosmio E15-AV101 15' LCD screen went black
My Toshiba Qosmio E15-AV101 15' LCD screen went black with red, blue, and green vertical lines. When i turned my laptop on, the screen just went white, then slowly from the corners, it turned black with red, blue, and green vertical lines. When i connect my laptop with an external monitor via the serial port, everything worked on the external monitor, except for the laptop LCD screen. Also, there were no signs to indicate any problems whatsoever, the LCD screen just went out. Could it be the LCD screen itself or the invertor? Any advice what the problem could be.
Thanks
Toshiba Qosmio E15-AV101 15' LCD screen went black - utube.png You-Tube video "
Posted on Mar 31, 2008
If you are willing to sell the shell of your qosmio, i might be willing to buy it. you can keep the hard drive &/or the battery. i'm pretty much interested in the motherboard. let me know. i can be emailed at [email protected] or you can call my cell at 513-703-0944.
Posted on May 02, 2008
  • 151 Answers
Check power supply section .check pf in power section it may be fault.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 21, 2008
SOURCE:
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
How to rplace cpu fan for toshiba qosmio e15
See the below video for guidance on how to take apart your laptop.
Dec 16, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Video card went out on laptop. Replaced Motherboard. Works great, but now a thin line vertically on monitor. Hooked up to outside monitor and no line. Suspect LCD going out?
The problem description provided by you clearly reveals that the issue is with the LCD screen and a replacement is required.
This is a common problem. Most people just live with it. You can make it less noticeable by changing your background color on your desktop to a pure white color.
Oct 21, 2009 | Toshiba G15-AV501 Qosmio Notebook
3 tinny vertical lines across the screen
If they are vertical it means that the pcb board at the top of the lcd is defective and the lcd needs to be replaced
Oct 03, 2009 | Toshiba Qosmio G35-AV600 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Display problem
could be 2 main causes, either the LCD converter under or behind the screen under the beizel has failed and is messing up the display, or simply the sreen could have been cracked at one point, either way these parts have to be obtained from toshiba.. EMPR do toshibas spare parts, if you are in australia
www.tosh.empr.com.au
Dec 10, 2007 | Toshiba Qosmio G35-AV600 Notebook
Open Questions:
Hackers apparently from India have taken over FIXYA and 6YA. Don't trust your password, credit card information, or personal information here. This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Oct 16, 2019 | Best Computers & Internet
Computers & Internet Logo
1,237 people viewed this question
Ekse
Alun Cox
