Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Green Bows on top and bottom
I ran the convergence but the crosses on the top right and the bottom three are distorted for the green only. Middle part of the screen is fine. What do I need to replace? Is this the green gun or just some convergence chip??
  • 4,234 Answers
This is most likely either bad connections on the convergence IC or a defective IC. Try resoldering the pins first. If that fails to resolve the problem, replace the IC.
Dan
Posted on Mar 18, 2008
SOURCE:
Focus problem, see Green and Red misalignment;
this could be caused by the loss of the power to the converge circuit or the failure of the converge chips-stk-xxx-xxx if the problem pops in and out it's a connection problem.
Oct 09, 2008 | Sony KP-46WT500 46" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
