Hp plazma tv
HELLO i have a plazma tv that has 2 inputs that work and one that doe'snt work do you have any solution?
  • 4,234 Answers
What is the make and model and what inputs work and what one does not?
Thanks,
Dan
Posted on Mar 18, 2008
Toshiba 42DPC85
Video 1 and HDMI don't work with cable and I can't get a visual for the channels only volume and other menu items. My PS3 works fine. Thanks so much
Posted on Dec 26, 2009
SOURCE:
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
I want to install gprs settings in nokia 5230 model please give the procedure
If ua usng aircl service,snt a msg to them.hea s wat u hv to snt.."ALL" n snt it to 121..ua intrnt settings wl b delivrd 2 u
Jan 27, 2011 | Nokia 5230 Cell Phone
I have a Samsung HP-T4264 plasma tv with a badly cracked screen. Can this screen be replaced with one from a Samsung HP-R4252C plasma TV.
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
Jan 21, 2010 | Samsung HP-T4264 42 in. Plasma HDTV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I am not able to connect to the tv by my toshia satellite pro m200, through the av cable....
What is it you are receiving when you connected? No signal?
You may need to setup your Computer to TV mode. Or even TV you may need to setup INPUT or anyother connections that required.
For example: I have sony Monitor/LCD but also works as TV it is Plazma. Has got connection with INPUT VGA S-VIDEO. I use Svideo for video connection and I use INPUT connection to Computer where I take cable tv channels.You need to see If your computer support for TV if does, make sure if You need docking station or not. My suggestion go to toshiba page and read user guide and reqs. for TV connection. probably your are missing something.
JMC
Aug 16, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Split Screen
how to repair a plazma tv with a split screen image
Feb 29, 2008 | LG 50PX4DR 50 in. Plasma TV
LG LFD790 installed with cable
if there is an input on the back of your cable reciever get a fiber optics cable and put it in to your theater system and into the box then select "ez/optical" and your tv should come through, or you can connect the fiber optics cable on the back of your tv into the system and keep the tv volume off
Dec 25, 2007 | LG LFD790 System
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
