Question about KitchenAid KESC307 Electric Kitchen Range
Kitchen aid superba electric convection range
My oven,broiler elements inside don't work at all,top burners do ,was told to replace computer board and power board but oven still does'nt work.What else
  • 4 more comments
  • rusty7888 Apr 21, 2008
    My top burners work fine but the oven is dead with dead elctronics, not even the clock works. Is it the power board or the inline fuse your talkong about
  • ddhhcm May 13, 2008
    My burner elements work and my clock works. However nothing inside the oven are working.
  • tommusgrave Jun 13, 2008
    top burners work, oven is dead except for the light, touch keys do not respond, receive error message of F5:E3. I have tested for a short in the door button, seems good.
  • ericchandler Sep 24, 2008
    Range top works, oven Light works, door lock works for clean mode convection fan comes on, clock and all programs work it is not giving me any problem codes, but neither elements work...Please Help!!!!!
    Chandler
  • Anonymous Mar 14, 2014
    Oven not working
  • Anonymous Mar 25, 2014
    oven will not light
    President:
  • KitchenAid Master
  • 2,651 Answers
Ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
SOURCE:
My kitchen aid "superba " convection oven is not maintaining it's temperature. It has only one heating element on top.
There is a good chance there is a hidden element on the bottom. This is common on higher end ranges. It could be a bad element.
Sep 28, 2014 | Kitchen Ranges
My kitchen aid electric convection oven (superba series) is not maintaining it's temp. I do not believe the fan is turning. My oven has only one baking element on top.
You do have a lower element. On convection ovens they are usually covered. If you look in the bottom of you oven you should see it is elevated in a rectangular metal cover. You should be able to slide it forward and lift it away to expose bottom element.
If visual inspection shows no signs of burn out on it then you will have to test to see if it is getting power.
Can you tell if the top element is working for sure?
Seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchenaid electric convection range - preheats just perfectly in regular bake mode, but takes forever on convection bake. This model has 3 elements - broiler, lower covered element and a convection...
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 24, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Oven Not Working
It could be the element, but if neither the top or bottom element are coming on, it could be an issue with the electronics... Have you tried any of the other oven functions? Is it a convection oven? Maybe try using the convection bake or roast/convection roast functions..(roast function doesn't go through a pre-heat cycle, I have the same stove). If it's still under warranty, I would be calling for service.
Jan 06, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Broiler won't light
gas=replace igniter(top)
electric=replace top black heating element!
Oct 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
919 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
