Re My lavamat
Thanks, Faggly.
I can only describe the noise as grating, as if metal on metal.
It is evident in particular on rotating.
JOhn (admin47)
    Scholar:
  • 74 Answers
Hiya admin47 John...
unfortunately.. what you are describing is the drum bearing has very likely collapsed, this can be caused for a number of reasons..
1. life and general wear and tear. How old is the machine?
2. Uneven placement of an appliance, which puts extra strain on the bearings, especially when overloaded.
3.Expect to pay around £60 -110 inclusive of parts and labour if you in Uk.. and dependant on where you live!
Obvious question but do you know if there is an extended warranty on the parts... not labour...when you first purchased the appliance, sometimes worth double checking!
Posted on Mar 19, 2008
Bosch Maxx WFL 2260 making intermittent noises. Our machine works well but of late it has taken to making a graunching noise (similar to what you get in a car when you don't use the clutch properly). It...
you have a coin or a hairclim or metal part of a zip that is stuck in the filter where the wings of the water pump rotates against it.
Open the filter and try to remove it. Unplug the power first.
Good luck
Bye
Jan 24, 2015 | Bosch Washing Machines
Bosch wfk 2800 drum makes a noise when turned around
When you rotate the drum by hand slowly does it feel bumpy and still make a noise? If so suspect the bearings on the drum to be the culprit. Hope this helps.
Nov 17, 2013 | Washing Machines
A "clunking" noise when stitching
some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Dec 31, 2012 | Sewing Machines
I would like to read manual (hand-book) for washer AEG lavamat 74820 Could you send me some info? Thanks so much - Valdis
Sorry but FixYa cannot do that direct- members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 19, 2011 | AEG Lavamat 72640 Front Load Washer
My AEG Lavamat 52810 has become faulty. The machine pauses about ten times during the cycle and the lamp marked "door" blinks. When I press the start button, it stops blinking and the cycle...
Hi Richard from retired Englishman in SW France,
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and
/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Aug 14, 2011 | Washing Machines
I have a 97 bravada, when driving caR ON STREETS OR HWY there is a chugging, thumping sound that is constant regardless of speed .. what is issue? Thank you! Alan
If its regular dose it increse with speed If so its something that is rotating like the wheels brake noise bearing noise drive shaft rubbing on something . I f you could describe the noise a little clearly and is there anything else like viberation with the noise and dose it sound matelic metal on metal
Feb 10, 2011 | 1997 Oldsmobile Bravada
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
Re: Lavamat 72630, 6 yrs old Very loud noise from drum movement, has increased over last ten washes. When machine is stopped, on rotating drum we note it is catching on something. Nothing rattling, don't...
Hiya admin47..... to be a litle more certain diagnosing your problem, please can you do the following.
1. with the washer empty.. ie the drum... please rotate the drum by hand at any speed you can get... without moving the drum sideways/backwards. Listen for any peculiar noises.
2. Then move the drum backwards at the bottom of the door ( dont force).. then let the drum housing go.. swinging by its own movement, again listen for any strange noises.
3. Do the same pushing the drum from the inside to the outer casing..again dont force.. let go listening again...
Please post me the results
Regards Faggly
Mar 18, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
