Question about Panasonic PT-53WX42 53" Rear Projection Television
Same problem with the 3 blinks
Although i had no convergence issues beforehand..it just wouldnt turn on yesterday...i called a guy and he said he would fix it for 240 and use Toshiba chips instead and that i would work..do you think that would be ok or is he hosing me?
the panasonic shop wanted to charge 350 bucks..so id rather go with the cheaper guy if i can.
  • Panasonic Master
  • 8,617 Answers
Thats an expensive price for 20 minutes worth of repair and 20 dollars in parts. For that price I would insist that he use origional SANYO ICs as sanyo designed the STK series Chip and even though other brands have the stk number they are cheap imitations. origional sanyo parts will come packaged with the sanyo UPC code on the package. Otherwise you will probaly end up with 5.99 cheap versions and they will only last a short period of time
Posted on Mar 24, 2008
Had convergence issues, green was okay, red wouldn't move horizontal, and blue wouldnt move vertical. Also, functions such as pincushion and tilt wouldn't work with red or blue. Replaced convergence IC,...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Mar 06, 2011 | Mitsubishi VS-45609 TV
My panasonic pt-53tw53 wont turn on. The power light blinks 3 times then pause then three times....etc. If I unplug the set and plug it back in, it will work again but just for a short time, then shuts...
The 3 blink error is the convergence circuits need repair. The Panasonic repair kit PT53WX53 convergence repair kit is the correct kit for your model. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with instructions.
Sep 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Color fading? is it the convergence?
I thought that I had the convergence dialed in . I played my xbox through it and it was looking good . I unplugged everything and put it up on stand and it wouldnt come on . Power button turns red then blinks 9 times but wont power up.
Oct 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a 65 inch Mitsubishi TV
unplug unit from surge or wall overnight. usually it takes hours for the caps to bleed out. if that doesnt solve issue. it could be the powersupply. hope that helps
Jun 05, 2009 | Televison & Video
I am thoroughly confused now
yes the convergence iCs will give you a severe picture distortion bowing in either from the top bottom or sides.as well as the 3-D look
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Hi, my t.v. is a Samsung rear projection and has what I can only describe as a "double picture". Had a repair man out yesterday who said it is not worth repairing as the message "no sensor...
A double picture to me is an indication of a convergence issue; from what you describe. WHat is the model for this set...i would have to know to be sure.. NO SENSOR data sounds like to me that the convergence has been messed up. No sensor data ussally means that the unit has lost calabration and will have to calabrated by a service tech... although these set are notourous i wouldnt give iup yet
Mar 04, 2008 | Televison & Video
Convergence issue?
This still could be the convergence . This will should be repaired by a tech if you do not know how to repair . Around $200 - $300 if you could get it to him or more if he has to make a service call . Call around for the best price as alot of shops vary in there charges. On this problem if it is the convergence make sure they will use the original IC's and not the cheap replacements as they do not hold up as long . Good luck
Mar 03, 2008 | JVC AV-48WP74 48" Rear Projection...
X830 problems
I had the same problem, Type this in your phone, *2767*6263#
It will clear out all your music and pictures so make sure you have them backed up.hope it works for you.
Feb 23, 2008 | Samsung SGH-X830 Cellular Phone
No power,red power lights keeps flashing.
I had the same problem with the 47" version. I called the Sears technician who tried for more than an hour to fix the problem, even calling Panasonic. Final solution: a board repair for $550. Now I have a plasma and a big desk.
Dec 02, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
