Question about Lakewood HV 18-c Floor / Box Fan
Can here motor running but blades do not turn
I am going to take it apart and see if it needs good cleaning
  • autumnsgirl May 29, 2008
    My pedastal fan just quit working . Does anyone have an idea of how I can repair this myself? What might be the cause?
    Thanks a million
    Carolyn
  • 871 Answers
Go and take it apart and clean it afterwards. dont forget to put oil. you might want to check the carbon inside the motor, they may need replacement.
Posted on Mar 18, 2008
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
The fan won't turn on at all.
Turn the fan to the on position and feel the motor casing. Is there any vibration at all? If not, refer to your operating manual to see if there's a fuse that can be replaced. Spare fuses are sometimes attached to the cord. Also try slightly spreading the 2 prongs that conduct electricity through the wall socket for good contact.
If you DO feel vibrating, try a maintenence cleaning and lubrication with either Graphite powder, 3 in 1 machine oil or WD40. I will take you through the steps:
1) unplug the fan
2) there will either be flip releases or notches to slightly pry loose the protective fan SCREEN blade housing. Pop this off and clean + dry it, set aside.
3) With fan blaeds exposed, look at the very center of the blades. There will be a large plastic nut that turns counter closkwise to release the fan blades. Do this, clean blades with warm soapy water. Rinse, dry and set aside.
Behind this will be another large plastic nut that releases the back side of the blade housing. This nut should turn closkwise this time. Again, clean, dry and set aside.
4) You should be down to the motor, stand and fan motor stem. Check for residue build up and clean with a Qtip. You can still remove the housing face and clean behind this if necessary. There will be several screws holding this on. Wiggle apart.
5) Lay fan on its back with the fan motor stem facing up toward the ceiling.
6) At the base of the stem, one small tap of one lubricant of your choise. No more than one quick shot WD40 or 2 drops 3 in 1 machine oil.
7) By hand, gently turn the motor stem closkwise to disburse lubricant. Wipe off any excess with a tissue.
Follow the reverse steps to reassemble. If you had latches on the face, line up the notches or the name on the face to be level at allignment. If you had to pry the face off with a flat blade screw driver, again line up the screen guard (face) and pop/squeaze it back together.
This maintence should be done twice per year to assure a long life! They are made to come apart for maintence so don't be afraid. Take pictures as you go for easy referrance. It relieves you of the tension of remembering what went where! Hope this was helpful!
Sep 22, 2011 | Windchaser 16 Oscillating Stand Fan, With...
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Fan does not come on
This will take some work, and some elbow grease, but what happened is the motor bushings most likely seized. Try turning the blades with your hand. If they are stiff, the bushings are seized. What you will have to do is take the fan apart. First by removing the blades, then by taking the motor off of the frame. Then depending on the type of bolts/ screws that hold the motor together, remove them. Then split the motor apart by taking a flat blade screwdriver and sliping it between the two pieces of the motor and turning it so they slip apart. then once the motor is apart, shine up and clean the motor's shaft so it is clcan and shiny. then do the same for the bushing/ beringholes in the motor's casing. then drip some oil in the berings, and on the motor shaft, and put the motor back together. then put it back on the frame, and plug the fan in. turn it on. the shaft should just spin without any help. if this does spin, put the blades back on, and put the guard back on. Then you sucessfully rebuilt the motor and the fan!
Aug 12, 2010 | Lakewood High-Velocity Fan
Humidifier fan blades stopped turning
Sounds like the brush is completely gone. You might be able to replace just the brush.
Good luck.
Mai
Apr 11, 2017 | Duracraft DCM200 2 Gallon Humidifier
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Office Equipment & Supplies
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Electric snowthrower motor turns, blades don't
You will have to take the top cover off of the snowblower there should be a belt that runs the auger
Dec 09, 2008 | Garden
My saw wont run only buzz
Sounds like teh capacitor has blown. These machines use normally use induction motors so they need the capacitor to take a charge and give the motor a kick in the right direction. You could CAREFULLY turn the machine on and spin the blade by hand. If it runs now then you will need a new capacitor.
Oct 14, 2008 | Saws
Lakewood HV 18-c Floor / Box Fan Logo
318 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
