Question about Acer Aspire™ T180 PC Desktop
No sound coming out of speaker
Speakers are not working on my Acre computer. no sound is coming out. What should I try to get this working?
  • Anonymous Mar 24, 2008
    yes plz
  • loui lou Dec 09, 2008
    Speaker is connected to PC , all okay with sound and then suddenly no sound even though its on. Not sure if I have knocked something on key board, not aware of altering anything and it was working fine.
    Any ideas ?
    Sergeant:
  • 406 Answers
Please see that you have not muted the sound device;
First check whether your speakers are on monitor (builtin) Or System Builtin;
No got Control panel Select> Sound Speech and audio devices>Sound and audio devices>See the audio tab.
Else you may see in the device manager that you have installed drivers or no;
Posted on Mar 18, 2008
I have plugged the speakers into a working outlet, and the speakers are connected to each other. To connect to the computer, I put it into the green insert. I can hear static coming out of the speakers,...
Try the speakers in some other desktop/laptop computer, to verify that the speakers are working correctly.
Try a different pair of speakers in your computer, to see if your computer is correctly sending "sound" through that 'green' port.
May 20, 2011 | Computers & Internet
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
My speakers are plugged in correctly but no sound is coming out of the speakers
Do you get sound out of the computer speaker (inside computer)? If not, go to device Manager and see if the sound drivers are loaded. If not, you will have to find the drivers and load them. If you sound from the computer speaker, then I would try the speakers on another computer that you know works with external speakers to ensure the speakers are good.
Apr 01, 2011 | Harman Kardon HK206 Computer Speakers
No sound from speakers
Test the speakers by plugging them into something you know has a jack that works, like an iPod or MP3 Player. If the speakers work on that then the issue is with your computer. If it does not work it may be the speakers. Make sure all the plugs are securely connected for both power and sound. If the speakers do work make sure that the computer isn't muted. If the sound is on try using a different port like the headphone port. See if sound comes out of the speakers then. If it still isn't working you may want to try uninstalling the sound drivers and downloading the latest ones to install.
Mar 29, 2011 | Dell A215 Computer Speakers
My computer speakers won't work. There is no sound. They will turn on, but no sound is coming out of either speaker. I tried all the windows help but nothing worked.
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 06, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
I cant get sound out of the speakers
Hi there bud...Try make sure you have the drivers installed for your Sound Card or motherboard...These should of come with the Sound card or Motherboard on a disk...Just run setup and install...if thats that the case here...what i suggest is try it on any other Pc that you know speakers have worked on...and if it does the same , then it could be that the speakers are faulty..
Hope this helped bud
Happy new year :)
Jan 08, 2010 | Labtec Pulse 485 Computer Speakers
I CAN'T BELEIVE THAT I HAVE TO PAY TO ASK A QUESTION
It makes DELL a very good company to deal with doesn't it! ACRE are very awkward all over the world!
Nov 08, 2009 | Acer Audio Players & Recorders
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
Acer Aspire™ T180 PC Desktop Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
