-   my xbox 360 says play dvd when its a game
-   Guest
Apr 21, 2009
-   my 360 reads nhl 2008 but not the 2009 and theres nothing wrong with the games i even rented another nhl 2009 and it didn't worked-   chargerman_4
Apr 04, 2009
-   I put the disc in the console goes searching and returns with "open tray". This happens on all discs.-   sellerman
Mar 29, 2009
-   says unreadable disc but all my games are brand new
-   me lad
Jan 05, 2009
-   all xbox discs including new ones fifa 09 and wwe2009 are non readable-   grainnemoran
I dismantled the console completely, removed & opened the DVD drive and pushed the laser assembly to its home position, carefully reconnected the disassembled unit to the mains inserted a disc & hey presto it worked perfectly!! I could have done all this by just opening the DVD drive &inserting a small flat screwdriver and pushing the laser gently. I enjoyed the experience though of cracking the console open & reassembling it successfully!
Listen to your dvd drive to see if it spins up or not when you put the disk in. If it does spin normally then you will be need a replacement laser.
If it does not spin correctly. The motor is stuck, sometimes if you open out the tray and stick something into the drive and give it a spin it will free the drive.
Check out this link if you have the Hitachi dvd in your xbox360
The likely hood is your spinner motor is bad. Crack the case. Take the dvd drive out and remove the top then reinstall in it original place. Don't install the plastic case. Turn it on by ejecting the the dvd (small hole on the left front use a pen tip) put a disc in then you can see if the disc spins or not if no then the spinner motor is bad. If you don't see the laser move or light up you may have a bad laser or the motor that moves the laser could be bad.
Though i fixed the Disc Read Error myself within anhour but please test the
below method at your OWN Risk. Please alsonote that microsoft is no longer
providing Extended warranty for E74Error.
Check out this DIY Video
Guide,that explains step by step instructions to fix Disc Read Error
yourselfwithin an hour. It also provides the money back guarantee in case youare
not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.......................
If you have unplugged your console, the time and date need to be reset. If the time and date are not correct, the xbox doesn't recognize the media. This fixed mine....some problems are more serious.
it says im connected to my router but then I test connection and it says failed to me linking to the...
(More)
it says im connected to my router but then I test connection and it says failed to me linking to the internet, therefore i cant log on to xbox live
when i turn my xbox on no picture appears but the sound works. i checked my cables, tried different...
(More)
when i turn my xbox on no picture appears but the sound works. i checked my cables, tried different ones and tried a different tv. i have had my xbox on the same tv and it just now started after about 2 years
