Question about Kenwood Audio Players & Recorders
Kenwood Model#ka-893 radio blowed
Kenwood Model#ka-893 radio blowed a fuse changed fuse now lights come on but no music well play, Jodey
5 Suggested Answers
SOURCE: Kenwood 7202 Amp that is blowing fuses
i had the same problem ! that amp is underated!
it should have 2 / 40 amp fuses i had to direct wire the fuse!
not a smart thing to do but it never shut off again and i havent
had any problems at all i put a 60 amp fuse at battery!
melted 1 wire that was two small ! its banging 2 / 12inch solo barics and sounds great hits deep. again not smart BUT it works.
Posted on Dec 01, 2007
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
nuwan chinth
  • 111 Answers
SOURCE: Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Posted on Jan 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: when i power up my kenwood ka 893
Can you elaborate on this, "I'm wondering if it has to do with a speaker not being in correct post./negitave place"? --- What did you see or do that makes you wonder?
You didn't answer if the fuses were blown or if you just changed them for lack of anything better to try, like checking the manual, which says to suspect shorted speaker wires if "- - - - - - -" is blinking on the display.
Disconnect the speaker wires and see if that helps the receiver boot up, then diagnose the short.
If it doesn't come back to life I'd suspect it got fried by a power surge or static. I hope not.
Posted on Apr 02, 2010
My kenwood ka-87 stereo integrated amplifier keeps blowing fuses any idea why?
First I would disconnect the speakers and then power up and see if it blows if not add a speaker at a time and make sure the speaker is not grounding on metal
Jun 25, 2016 | Kenwood Car Audio & Video
My kenwood ka-87 keeps blowing fuse any idea why?
Disconnect the speakers then power on,and if it still blows it may need service there maybe some thing wrong with the power supply good luck
I have a Kenwood KA 893. I have no control over the volume. The dial is spotty. Sometimes I can turn the volume up but it usually does what it wants. I do not have the remote.
Sounds to be dirty. There is a thing called tuner cleaner you can use to clean it. You will need to remove the control knob and try spraying into the control,but you may have to get inside to clean it up good by breaking down the unit.
Nov 25, 2014 | Kenwood Food Mixers
When i power up my kenwood ka 893 amp/reciver it does nothing i have replaced all 3 fuses but it does flash bars on the panel
Apr 01, 2010 | Audio Players & Recorders
Kenwood XD-571S displyaing ''test 00''
TRY TAKING THE COVER OFF AND CHECK ALL FUSES ,,,ALSO BLOW ALL THE DUST OUT OF IT
May 13, 2009 | Kenwood Audio Players & Recorders
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
I have a kenwood KA 1060 amp, and recently changed the fuse on the first PCB board where the mains power lead connects to the unit as the fuse had blown. After doing so and testing it again the fuse has...
Most likely the output transistors are shorted. This causes the output stage to draw too much current and blows the fuses. Expect a parts cost around $20-$40. Add in the local labor rate for the total repair cost.
Dan
Apr 17, 2008 | Audio Players & Recorders
69 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
