Question about Thermos Grill2Go Fire+Ice
Grill 2 go parts
Hi i`ve bought a grill 2 go on ebay last year but its got no gas connection or pipe where can i get the connection from
  • 2 more comments
  • Anonymous Jul 22, 2008
    hi , also require gas connection for thermos grill 2 go ,connection to burner ,thanks for your help.
  • areinard Feb 07, 2009
    My Fire+ICe model 465630003 also does not have the propane gas connector or the gas line. Do I need 1, and if so, where can I find those replacement parts.
  • trolley_bob Apr 19, 2009
    I have a grill 2 go and don't have the hose and regulator to hook it to a 20# propane tank.How and where can I find them
  • MrsGriff Apr 22, 2009
    I have the regulator but don't know if there should be an O-ring on it to connect it to the grill. Seems a loose fit.
I have the same problem no reg. and no connection pipe, where can I get?
Posted on Sep 29, 2008
Posted on Aug 22, 2010
    Problem Solver:
  • 13 Answers
I have them for sale
do you need the burner or the regulator
Posted on Jul 13, 2008
  • 1 more comment
  • cadial Feb 14, 2009
    I SELL THE FIRE AND ICE AND THE GRILL 2 GO REGULATORS. THERE 50.00 DELIVERED.
    TAKE PAYPAL OR CASHIERS CHECK. 706-681-6450
  • bribiebirds Nov 05, 2010
    wil your regulators fit a jackeroo grill 2 go ??
    please email me at bribiebirds@gmail.com
    thanks ****
  • Adrian Shone
    Adrian Shone Jun 06, 2011
    hi iam from uk how can i order the connector and reg for the fire and iec bbq thanks ade
Will a regulator for a thermos grill 2 go fit a fire and ice grill 2 go
Posted on Sep 27, 2009
I have a Weber Genesis S-330. My house has a natural gas pipe out to my deck with a shut-off value. Do I need to buy a seperate part to connect the hose to the gas line? Can't seem to figure out how i
Hi Jamie Duke, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Did your grill come with a grey rubber gas hose and/or a quick-disconnect fitting? The quick disc. (typically 1/4", 3/8" or 1/2" size) should hook up to your shut off valve, but you may need to buy a pipe fitting to adapt to it, that is, if the shutoff valve is not the same size. Let me know if I can be of any assistance. Douglas
Mar 31, 2014 | Weber Grilling
I've had my grill for a few years and when i turned it on last night, i could barely see the flames and i had both burners on hi. I cleaned (took a wire brush) to where the flames get out and still...
You may have to recheck the tank for full. If you forgot to turn off the tank after the last time you used the grill, the tank could have leaked down. I always keep a spare full tank for just those types of problems. If the tank is full, then the regulator may have a problem. That grill should be able to get over 300 degrees.
Jul 07, 2011 | Weber Genesis Silver A Grill
We bought a house last year that has a pool with a Laars Lite 2 heater. The drain plugs were not on the unit and we've tried to replace them, but it seems that either the treads are stripped or they...
We come across these from time to time and we were told that when the part is installed at the factory it is by machine...sometimes they end up so tight that removing them strips the threads. In the past we take a pipe tap out and re-thread the hole and then the new drain plugs will fit fine. It is a 1/4" MPT (often referred to as NPT on taps) pipe tap (tapered). You may find a local pool or pump service company or maybe a plumber that will lend it or make the service call to do it for a reasonable price.
John
Jun 21, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Vermont Casting VM450SSP Grill that needs a new Hose Regulator-S/B Valve Assembly. I have ordered two separate times what "Appliance Factory Parts" thinks is the part I need and both...
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
Jun 18, 2011 | Vermont American Tool Company VM450SSP...
Customer has had grill since 2008 and the pipes where gas comes in has rusted and broken down
I suspect, the piping that was used originally used for the incoming has line was not Black Iron Pipe as required. It was probably galvanized pipe instead. Which, has never, ever been approved for gas delivery piping. Even under the worse conditions, unpainted Black Iron Pipe would not have rusted thru in just 3 years.
Solution: Replace all of the existing gas piping with either Black Iron Pipe (paint it after installation), Flexible Copper Tubing (requires no paint) or Flexible, Stainless Steel, Vinyl Coated Pipe. The piping diameter should be a minimum of 1/2" OD.
If this is not a built-in grill (i.e. Outdoor Kitchen) and is still a cart grill. Code requires that there not only be an accessible gas line shut off valve within 3' feet of the grill. But, from that point on to the grill, it must have a 12' long rubber, quick disconnect, gas hose.
Hope this helped you. Please let be know.
Jun 16, 2011 | Brinkmann Charmglow 810-7600-S Grill
How do I connect my propane gas grill up to the 1/2 inch gas connection that goes to my large propane tank that is also used for the gas firplace. The large tank does have a regulator. This would elimate...
Thomas, unless you have flaring tools, 1/2" flexible copper refrigerant type piping, the necessary flared couplings, unions, inline shutoff valve, etc., as well as an extensive knowledge of pipe fitting and installation of gas appliances, I don't recommend you under taking this as a DIY project. There are just to many things that can go wrong and is best left to the pros. I am sure your propane provider can do it for you. After all, you'll be using more propane and they like that. With that said, it can not be directly hard piped to the grill. Either you or the gas company can provide a 12' long, rubber, quick disconnect gas hose, that will go from the ON/OFF gas line valve to the grill. As that is a national code requirement.
Good luck and Happy Grilling.
Apr 21, 2011 | Grilling
What is the NATURAL gas flow rating CFM for a Weber Genesis S-330 grill at 60,000 BTU max? I will be using 1/2" black pipe 40ft long run to the grill off a 3/4" main line - ok? Thanks...Dennis
Dennis, it's not the CFM you need to know, it's the water column inch that is required. In this case it's 7 inches. Also, if you're burying this 40' run, you can't use black iron pipe. A less labor intensive and perhaps less expensive way to go is 1/2" Flexible Copper Refrigerant Tubing. It's comes in 50' & 100 ' roles from your local home center. Even if you're not burying the line, it's a better way to go, as you'll have fewer fittings that could be prone to leaking. I
n addition, you'll also need and an inline gas shut off valve at the connection before the grill and a 12' long quick disconnect gas hose, that connects to the copper pipe connection at the shut off valve and then to the grill. This is a code requirement.
Now, with all this said, I hope you have a Genesis S-330 Natural Gas Grill. Because, the Genesis Propane Grills ARE NOT convertible to Natural Gas. And Genesis Natural Grills ARE NOT convertible to Propane.
Hope all this helped you make the right decisions. Have a great day and Happy Grilling!
Apr 13, 2011 | Weber Grilling
Hi, I have a year old 12395 BBQ. Last week when using it for the first time I noticed a flame creeping down the rubber pipe, it appeared to be leaking gas from the side grill brass valve. I turned the gas...
Kevin, While I can't offer a suggestion regarding the cause of the problem, I'd like to stress to danger of a defective gas unit. A small LPG tank can explode with enough force to blow a hole through a wall. I'd suggest having it examined by someone qualified to service gas fittings.
Apr 26, 2010 | Grilling
Char-Broil QuickSet. cheap old school. i purchased a natural gas conversion kit for it. but it seems that there is no way to connect the hose to the grill. anyone suggestions/ adapters that you could...
Hi, Kelly,
I converted one a few years back, and got most all of the parts I needed from the local gas company. The few parts they didn't have, I got from Lowe's. I got something I wasn't expecting in the bargain - expert advice at the gas company. They just loved talking about converting to NatGas and couldn't have been more helpful. Try your local company. I bet they have the same type of folks there. By the bye, some gas co's will make the conversion to NatGas for you for free. Check it out!
Regards! --W/D--
Jul 12, 2009 | Grilling
Thermos Grill2Go Fire+Ice Logo
3,101 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
