Question about Intel SuperMicro SUPER Motherboard - 810 (370SEAO)
Ram gets detected only to half of the value specified
I have a intel 810 chipset ,i have inserted a pc133/100 dd ram of 256mb but it gets detected only to 128 mb ,should i change my jumper settings or try with another new ram .
pradhan
pradhan1987@gmail.com
    President:
  • 2,351 Answers
Your Intel has a built in graphics card & it share's your system memory to run. You can lower the total amount of system memory being used by entering your bios & changing the amount of memory for the video to use.
Increase your system memory to 512MB or 768MB
Good Luck & kind Regards.
& please vote.
Posted on Mar 18, 2008
    Genius:
  • 1,913 Answers
Dear pradhan
your ram 256 but i think your ram memory shared with disply memory so . first restart your system and press DEL key untill u enter in bios setup.then go tothe advanced option and disable graphic memory then save settings and restart pc . your problem is solved.
I have ausus motherboard Pentium 04, 2.4 ghz processor and DDR ram 256mb, When i try to extend its ram by 256mb, it starts beep. i M sick of this problem. kindly guide me . how this problem can be solved.
you mean you inserted same value 256mb to become 512mb? some motherboard has new hardware detector in your PC...it may detect a new hardware insterted...follow screen configuration after you insterted the expansion RAM...
May 25, 2010 | ASUS K8V-MX Motherboard
I want to locate jumper pin to clear bios because its showing cmos checksum error and i am unable to use keyboard to enter booting also cn anyone help...am using intel 810,p3 processor
You can take out cmos battery for 5 minutes or 10 and CMOS will automatically discharges. You havent specify motherboard name to give exact instructions but what i say works for 95% of motherboard.
Aug 04, 2009 | ASUS Intel 810 Chipset CUW-FX Motherboard
The 256MB SDRAM is showing as 128 MB SD RAM
if you have onboard graphics card that shares the ram memory with your graphics card then the configuration in the bios will determine how much memory is shared with your graphics card so you will lose memory there. Also windows xp does not always report the correct amount of memory so check with cpu z or wcpuid or another utility to check.
Also when you restart your computer when it detects the memory how much does it show that is installed there or if you go into the bios does it show the correct amount.
If it does not then it is not compatable and I would suggest going to www.crucial.com and selecting / getting the correct memory by selecting the correct computer / motherboard that you have.
Apr 10, 2009 | Computers & Internet
2 RAMs are not getting detected together -- Intel D101GGC
hi im josh in cebu phils. friend no setting to be modified the problem is in *********** board.it can not detect two memory at a time especially having different value. coz when the memory works it will swap since one of the memory is hgher it will create complications.so to avoid such problem you choose to use the same value of memory in both memory banks. like if youre using 256 of the 1st memory bank use alson 256 for 2nd memory bank. then try to use the same brand for better. good luck!
Feb 19, 2009 | Intel D101GGCL Motherboard
Installation problem
i think you are having problem with ram that you have not given here
Jan 19, 2009 | ASUS Intel 810 Chipset P3W Motherboard
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
RAM SUPPORT
it depend on motherboard model not the chipset
Sep 02, 2008 | Intel Motherboard
Question from docustor re:ASUS Intel 810 Chipset MEW-AM
the intel 810 chipset requires very specifically made 256meg sticks to support that much memory. the 256 meg standard has changed, and the 810 wont support the ram unless it is made by the old specs. smaller ram sticks such as 64 and 128 will not have this problem.
Jul 19, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Computers & Internet Logo
157 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
