Question about Xerox Phaser 8400 Laser Printer
Phaser 84OOn Part Number
I just read your previous post and must thank you as I checked the part and it was cracked. Where can I order this part number and how do I replace it.
    President:
  • 2,072 Answers
What part are you looking for??
Posted on Mar 23, 2008
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Phaser 8560MFP/N System error 07,010.43.14452
The probable situation is that 2 camshafts (020K14800 & 008K02160) have cracked, and now have taken out the Process Motor (127K53240)
Replace all 3 together, and get the "homing the process motor" and "homing the head tilt mechanism" instructions.
-Whit :)
Jun 23, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
This was posted previously. M15i does not turn
in following order, either and most likely the Power supply is bad, That is located under the cover where the paper comes out, On the left side of the machine, where the on off switch is, there are 2 screws that hold the cover on, the power supply is there..A fuse on it may be bad, but that power supply fails due to heat.
Next is the main board failure, but that is less likely , about a 10 percent chance. The power supply print board crack from heat, and the filter capacitors also fail.
Feb 24, 2009 | Xerox WorkCentre M15i Laser Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
WS-55809 TV Won't Come On W/Fault Code 22
replace the fuses again and the IC8c01 and IC8C02 all together
Nov 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Adding ink
you leave all remaining pieces in the machine unless they are cracked or twisted.
Sep 08, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Laser Printer Logo
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
