Question about Sanyo PLC XU35 Multimedia Projector
Image goes Dim
I have a Sanyo Pro xtraX when I turn it on the image is dim. The lamp replacement light is not on.
  • mr333 Apr 07, 2008
    I took out the lamp and it looked fine but I did order a replacement lamp and will be replacing it when it arrives. Thank for the suggestion.
  • 563 Answers
Hi there
Keep in mind that the light will only flicker if the bulb reaches a certain amount of hours or if it is damaged completely.
Try taking out the lamp and check on the inside of the shaft if you see any black vein looking marks on it or if there is a bubble at the bottom of the shaft - this normally causes the lamp to be very dim and will need replacement.
Posted on Apr 03, 2008
Will a bad or old lamp cause my projector not to display a picture?
If it is lighting up - even poorly - then the image should be visible irrespective of the lamp condition - try it in a back out condition. Another test would be to bring up the menu options - if they are visible it will confirm that the fault lies more in the area of the input side of things.
May 29, 2015 | Sanyo Pro Xtrax Projector
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Screen goes dim
It sounds that its back-light have a problem. Check its back-light CCFL lamps, and back-light inverter board.
Apr 27, 2013 | Sanyo Televison & Video
The lower part of the display is dim.
the fly-eye lens (diffuser) is starting to fry and needs to be replaced. there is one right inside the lamp housing and one on the other side of the first. the second one is the one that usually fries. if that is ok, then check the light filters next to the lcd panels. they fry due to excessive dust and heat. if one of those go, you'll need to replace the entire optical engine.
Oct 15, 2009 | Sanyo PLC-XT16 Multimedia Projector
Acer 6930 won't light?
You could have an inverter problem, it supplies high voltage to the CCFL backlight lamp or you have a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 18, 2009 | Acer Aspire 6930-6455 Notebook PC
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Jun 08, 2008 | Sanyo PLC XU35 Multimedia Projector
Projection is so dim
Hi there
Sounds to me like it is time for a new lamp.
Jan 23, 2008 | HP Digital Projector Vp6120 Multimedia...
Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Sep 03, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
677 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
