Question about Kenmore 24 in. 16299 Built-in Dishwasher
Dishwasher not cleaning the dishes anymore, leaves a film on
It runs the full cycle but leaves a film of detergent on the dishes
    President:
  • 1,197 Answers
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
SOURCE:
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
Tip
Dishwasher Residue and Film on Dishes
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Feb 20, 2011 | Dishwashers
Our dishwasher doesn't seem to be getting the dishes clean anymore and leaves a residue. We have changed detergents and all that, but to no avail. Is there a filter or something that needs to be cleaned...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
heatman101
Feb 11, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Dishwasher is about 8 years old an dishes are just not as clean. Looks like they have a bit of residue on the dishes. Dishes clean in terms of food, but just not squeaky clean look anymore. Way to clean...
heatman101
Aug 21, 2010 | Asko D1876 Dishwasher
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dish water not emptying out after a full cycle.
heatman101
Feb 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Does not clean well and leaves detergent residue even after several cycles. Tried changing from detergent tabs to gel, no real change.
heatman101
Dec 21, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 24 in. 16299 Built-in Dishwasher Logo
319 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
