Question about Pioneer CDJ-800 Turntable
PIONNER cdj800 disc loads but wont read. when i insert a cd it takes forever, never loads and ends up ejecting i tried diff cds and all
  • 2 more comments
  • Makielad Mar 25, 2008
    I insert a CD it spins for 20-30 seconds then ejects saying - no disc! Ive only had this player 3 years and its stopped playing CDs? Why? This is meant to be a proffessional piece of equiptment, not a cheap imitaton! This problem needs addressing by Pioneer! Ive had cheap CD players over 10 years and the laser on them is still going!
  • thatblokedan Jul 31, 2008
    I also have had the problem where:
    When you insert a disc, the screen displays 'LOADin' for around 30-40 seconds then ejects the disc.
    I fixed my CDJ800 with the part suggested on this link found on 'FixYa' http://1200s.com/Store/p320015/Pioneer_-... This only seemed to be a temporary fix.
    After 10 hours of perfect use, again I am encountering the same problem. I have checked that all connections are solid and that the part is installed correctly.
  • Anonymous Sep 24, 2008
    second time this has happend to me what a joke!
  • Anonymous Oct 09, 2008
    i have same problem. I opened it up, load mechanism seem to work but nothing happens excerpt a fex spin-ups
    after about 30 seconds cd ejects
  • 515 Answers
Your tray assembly is damaged, and will more than likely need to be replaced. This is a common issue for this unit. The part is available HERE, however self-repair is not recommended. I would also suggest taking in to a service center for a proper diagnosis.
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Dec 29, 2007 | Philips CDR778 2-Disc CD Recorder
Stuck CDs
If you don't care about the disc player and want to get the cd's out you can easily take it apart yourself[make sure you unplug it]
Dec 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Pioneer cdj 800
sounds like a laser pick-up fault, if you havent had it repaired you can send it to us.
thanks.
Oct 05, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
694 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
