Toshiba,Color Television, CN32G90/CN36G95
Acouple of months ago my PIP stopped work. I can bring in the PIP, but no picture appears. I am using my remote to control all aspect. Is there a setting or connection for me to check. Would apprecate hearing from you on this matter. Thank You.
Martin Nobis mortynobis@suddenlink.net
  • 65 Answers
SOURCE: Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Posted on Dec 09, 2006
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
thecritter
  • 29 Answers
SOURCE: Remote control key sequences.
That sounds like something that would be in a service manual. Now that your tv warranty is expired, you can probably buy the service manual off samsungparts.com. I wouldn't have suggested that if your tv was in warranty, because that procedure would be in the service menu, which only Samsung trained technicians have access to when the product is in warranty. Just remember, if you go in the service menu and mess things up and can't fix it, you would probably need service for the tv.
Posted on Mar 01, 2008
JULIANFIX
  • 975 Answers
SOURCE: TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
Posted on Apr 16, 2008
SOURCE: PIP DOESN'T WORK ON MY REMOTE drc800
I just looked this up myself. It said you have to have two tuners to get PIP. You can have PIP with another source like vcr or DVd with the TV.
That is all the manufacturer said.
Posted on Nov 07, 2008
I have a 5 year old hln5065w tv which has been making a noise seemingly coming from the fan for 6 months without any picture problems. Now it has horizontal fine lines constantly going upwards, as if the...
Noise is your Color Wheel and Bad Capacitors in power supply will cause Lines if you see any that are swollen,vente or puffed up on Top they are Bad
Go tyo Encompass Parts Distrubtion and type in your Model Number it will list Part number for Color Wheel and if they have any in stock 1-800-638-3328
Jun 26, 2010 | Samsung HLN5065W 50" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
2 screens
You're talking about picture-in-picture. Simply hook up a second source or split the one cable input you have now into two leads with a splitter from somewhere like Radio Shack. Then bring up the PIP and select the input. Now you have two different things to watch each from their own channel. This wont work if you have dish... But you could watch the DVD perhaps if you hook it into one of the available inputs in the back of the Tv and select that input in PIP mode.
Good Luck!
Bill
Oct 18, 2008 | Toshiba 57H82 57" Rear Projection...
Ilo problem
What I hear you saying is that your main television tuner shows lines only while the PIP is functioning properly. The PIP works by using a separate tuner from the main tuner of your television (like a vcr tuner). Since the PIP works then it appears that your main tv tuner is not working anymore. It will probably have to be replaced. I recommend looking at our online technician list for a professional near you.
Good luck :)
Jun 20, 2008 | iLO 3200 32 in. LCD Television
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
No sound on my toshiba television
just be basic....dvd is ouput goto tv input...watch the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Lost color sync
sounds like you have a convergence problem. replace the 2 convergence chips STK 390-110.
Feb 04, 2007 | Toshiba TP50G60 50" Rear Projection...
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
