Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Error C31:30 Capstan Motor
Okay, I read all the threads about hitting the Sony cameras to fix errors. Then, I finally ran into a post where someone said that the error is commonly caused by a loose plug, hence hitting it may jiggle the plug into the right place. I opened up both sides of the camera and jiggled all the connections I could find, but it still will not accept a tape.
One of our VX2100s here at the school makes noise, as if it is playing a tape, as soon as you put a battery on it, with power on or off. When you hit eject, it makes the noise for ten seconds and then ejects. When you put a tape in, it gives the C31:30 error. Does the camera think there is a tape in it already?
  • Anonymous May 08, 2008
    I have had the c31:30 problem since the camera was 6 months old. It has been sent off twice under warrantee each time it came back working but took a few weeks to get it back each time. It has recently done it again but it is now out of warrantee. So after reading these forums I gave it a good slapping and it is working again..
    By the way I also tried talking to the engineers and they did not know what was wrong .. so they are obviously slapping it too
  • 80 Answers
SOURCE: tape ejects every 60 to 90 seconds regardless of the mode the camera is in
The flip up cover over the cassette housing has the "eject" button built into it. Sony has had problems with the flexible harness that connects this door to the camera body. The harness rubs against the metal frame of the camera and causes various malfunctions such as the constant eject symptom you are having. Sony service in Laredo, TX can repair this for you, it is no big deal. Good luck, this is a nice camera! Joe Weibel
Posted on Feb 16, 2007
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
  • 13 Answers
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Posted on Jan 28, 2008
  • 317 Answers
SOURCE: Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Posted on Feb 05, 2008
  • 5 Answers
SOURCE: Sony TRV460 error code C31:22
try slapping it at the side of the tape and than maybe push the reset button, it must solve your problem, its probably the little lever inside that tells the camera that there is a tape inside
Posted on Dec 04, 2008
It may be a capstan motor problem or a reel motor drive problem.
These kinds of things are best looked at by a technician as consumers are not familiar with taking these things apart and working on them.
Feb 20, 2013 | Sony Televison & Video
Error c:31:42
This code means
"FG fault during normal drum operations. Load the tape again, and perform operations from the beginning."
'C' indicates consumer-fixable problem.
'31' indicates the fix method (remove casette).
The 'FG' signal from the capstan motor is the tachometer signal that the camera uses to monitor the rotation of the capstan.
Jun 19, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony 570 dvcam error message 91-143 can you help
Microcomputer and its periphery device error
4: Capstan motor/capstan FG
2: Detected speed error
It looks like a bad capstan motor.
Dec 15, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
My sony digital handycam flashes C:31:42
C:31:42 indicates that you having a problem with capstan motor. It has to be replaced.
Nov 05, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Code C:31:30
the capstan motor of your camera is not working properly that why it indicate that error...some case it is a lost connection from the mainboard of the camera..
Aug 31, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Sony Mavica MVC CD500
It comes that Disk not being recognized. I had the same camera before. You need to use good quality CDRs or CD-RWs. Usually Sony Mavica disks best with that camera. Maybe you cannot find Mavica in market then go for Sony, Philips, Imation miniCDR/W. also keep the lens of the internal CD writer clean. If you need further assistance please post your question
Good Luck
Mar 05, 2008 | Sony Mavica MVC-CD500 Digital Camera
Sony DCRTRV 25 : Getting 31:23 error message
possible pinch roller problem.The pinch roller rubs against the capstan motor to pull out of the cassette .This pinch roller seems to fall completely or loose causing the error.The other possiblity is that the capstan motor is not turning ..might need repair..
Nov 29, 2007 | Sony Handycam DCR-TRV25 Mini DV Digital...
Sonytvr140 digital 8
Does the error appear when tape is inserted? Eject the mechadeck, take out the tape, try blowing hot air using hair blower for a short while, just to dry if there is any dew inside, if still the same, have the capstan motor replaced, thanks
Sep 11, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
31-30 flashing code
the capstan motor is the problem of your camera...that why c31:30 is appearing..there are 3 possible problem of the capstan motor...1 if the motor running too fast the sensor of the capstan is busted...2 may be the capstan is stuck up and there an object that clog to the motor ....3 may be be there no supply voltage to the capstan,poor connection to the main board socket...adjust the contact of the is need to disassemble the camera for doing this...if you are not a technician please don't try to fix your camera...i suggest you better go the qualified service center for fixing your camera...
Dec 03, 2006 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
125 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
