Question about Compaq Presario 700 470024-192 Notebook
Aligning ports How do i align my USB driver to my comm ports? I have looked under device manager, but I was unable to find ports.I have a Presario C500.
  • Anonymous May 11, 2010
    Under XP and Vista Comm ports are controlled and assigned by the OS. Are you trying to do something in particualar?
  • 655 Answers
There is no in built driver for USB to COM in windows. You need third party driver/software to do so. If you have any device with COM port interface that device might be shipped with supporting driver, please checkout.
If you don't have, You should try this link:
Thanks
Iqbal
Posted on Mar 27, 2008
SOURCE:
Some of the previous drivers are missing after my presario fell but fortunately other drivers work perfect
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 24, 2011 | Computers & Internet
In my computer -- properties-- hardware -- device manager -- PCI SIMPLE COMMUNICATION CONTROLLER IS SHOWING QUESTION MARK- DRIVER IS MISSING. MECHINE IS COMPAQ
ports(com&lpt)right click update driver hope this helps don
Mar 09, 2011 | Compaq Computers & Internet
The device has been detected but it is unable to open leaving an error message to insert a device even unable to format even in dos mode
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HP Compaq Presario V6030 usb ports don't work, is this something I can fix with drivers or can they be replaced.
First try these steps
1.Remove all the usb devices connected, then go to device manager and under Universal Serial Bus controlers uninstall all the usb root hub and then restart the computer
2. If it still doesnt work do a bios update from hp.com for your notebook and then restart and do a bios default too.
3. If these steps doesnt resolve the problem do a recovery and even after recovery the NBs usb ports doesnt work then mother board needs to be replaced as the usb ports are fixed in it.
Apr 15, 2010 | HP Compaq Presario V6030US (EZ503UA) PC...
Hi! i got a mobile presario compaq presario
First check with windows explorer if the devise is shown. If not check with devise manager if all usb ports are enabled (control panel-Hardware and sound-Device manager). Hope that helped!
Mar 22, 2010 | HP Compaq Presario C700T
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
How to find the com port for the USB driver
You have to look in the device manager. Usually you can get there by right clicking on My Computer then selecting Properties then the Hardware tab and Device Manager. If the CS1504 pulled a virtual COM port it will be listed under Ports (COM & LPT) as Prolific USB to Serial Comm Port with the port named at the end of the line.
Oct 14, 2009 | Symbol CS1504 Handheld Barcode Scanner
Compaq Presario 2500 USB Problem
go to control panel -device manager and see if you have all the latest drivers downloaded and if u dont then i would try and update them. if that doesnt work search up the specific driver u need online and download and install it.
Aug 10, 2009 | Compaq Computers & Internet
My usb port being not detected
Try downloading usb 2.0 drivers from microsoft.
Also look for drivers for your usb device..
check in device manager under usb devices and see if there is any yellow exclamation points next to any devices.
If that doesn't work your only option is to get a PCMCIA card that does USB 2.0
Jan 19, 2009 | Acer Aspire 3000 Notebook
Wireless in c770tu compaq
if unable to find a driver, go out and buy a usb wireless adapter, they are fairly cheap now.
Make sure you disable your old one under device manager
Aug 14, 2008 | Compaq Presario Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
