Question about DeLonghi DEFSGG24SS Gas Kitchen Range
Gas not reaching to the outlets on the top
The gas is going throught the pipes but when you turn the knob in the front it doesn,t come out of the top of the range or the oven.. can it be that, we should adjust the pressure regulator?
Sounds like the regulator is installed backwards. There is no adjustments that are made. Make sure you use a licensed plumber for any service. If you need help, call 866-844-6566 for assistance.
Thanks
Posted on Feb 28, 2009
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Tip
How to diagnose a propane BBQ flaming at control knobs
WARNING: this test can be dangerous; do it only if you know what you are doing!
I turned on my two burner propane BBQ. The left side worked OK but flames started coming out of the control knob (front area) on the right, and the right side burner was not lighting.
This is obviously gas leaking out of the front area. If the flames go out when you turn the knobs off then the leak is after the valves, controlled ny the knobs. If the flames stay on and only go out if you turn gas off at the tank then the leak is at the pipe entering the controls. In my case the flames went out with the controls, so I looked underneath. I slowly turned the knob down and saw that the flames (therefore the gas) was coming out of the air regulator/entry hole. I knew at once that the pipe going to the burner must be blocked. Sire enough, when I removed the burners I saw that an insect built a cocoon in the pipe. Clearing it solved the problem.
on Jun 11, 2015 | Cuisinart CGG-200 All Foods Propane BBQ...
Tip
How to test for gas leaks at furnace or elsewhere
Using a liquid dish soap diluted with water put in a spray bottle, like a glass cleaner bottle,use a 3:1 ratio of water to soap. Have good lighting and spray all lines and special attention to all connections. pay close attention to any bubbling. If any bubbles form, turn off gas, unscrew pipes at fittings and using a pipe thread sealer "pipe dope" coat threads liberally and reconnect fittings tightly. Retest after opening the gas valve. Gas lines use a globe valve which are open when the slotted knob is parallel to the length of the line. Be very careful not to allow any open flames until it is certain that all leaks are repaired. Warning never attempt to connect gas pipes or fittings without Pipe thread sealer or Teflon tape ; if it doesn't leak immediately it is certian to do so! Use good judgement or pay a proffessional with liability insurance.
on Sep 08, 2011 | Heating & Cooling
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
    If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
    Apr 29, 2012 | Kitchen Ranges
    I've had this unit for about 1-2 years, and it was working fine until last week. Pressure in tank but none in the outlet valve to the hose. Called Bostitch last week and the said it was the...
    Yes, if you can't remove the regulator due to it hitting the tank then just unscrew the entire pressure switch from the tank. It is right hand pipe thread just like the regulator. Some compressor's will allow you to start to turn (unscrew) the pressure switch just enough to move the regulator away from the tank so that you can replace it. If that doesn't work then you have to completely remove the switch.
    Jul 27, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
    When I go to start my grill, I turn on the gas and then the knob on the right side to spark the gas for the fire. When I turn the knob it does not spark the gas. Hoe do I troubleshoot what is wrong....
    It sounds like you have a rotary piezo igniter, which means you get one click, or spark, per rotation. If there is no click when you turn the knob, or the knob spins freely when you turn it, it has probably broken. If you pull the knob of, there should be two screws behind the knob that holds the igniter to the front panel. Hopefully you can remove the screws and reach behind the panel to remove the igniter. If this wont work, you have to remove the front panel. If the igniter is not broken, then check the wires and electrode for shorts.
    Jul 03, 2011 | Ducane 1005A (LP) Grill
    I have. A 40 gal. 40,0000 btu natural gas , how do u lite the pilot light
    Access is at the bottom of the water heater. There is a little cover you will have to take off. Look for the gas valve. (its where the gas will come in to the water heater) Follow the two lines that come off he bottom of the valve. They will lead you to the burner (big line) and the pilot(smaller line). The pilot is what you are looking for.
    1. locate the pilot (it will be 8" or so in to the water heater)(right next to the burner)
    2. Turn knob on top of gas valve to "pilot"
    3. Push down the knob on top of the valve that you just turned to "pilot" or there may be a lever right next to the knob on some models
    4.with a long fireplace match or bar b que lighter, while holding the knob down, reach your lighter to the pilot assembly. you may smell a little gas.
    5. The pilot will light, do not let go of the knob for 30-45 seconds
    6. After a few seconds let go of the knob and turn it to "on"
    7. Check your thermostat make sure it is not on "vacation" and turn it up to see if the burner ignites.
    You are ready for hot water if all works. Hope this helps you, have a good day.
    Apr 18, 2011 | General Electric Water Heaters
    I dont know how to relight my furnace not sure where the pilot is please help. Kathi
    First thing and this is very important turn the thermostat off. When you are in front of your furnace remove the top cover to expose the burners and pilot light. You will see a gas valve that has a knob, lever, or some kind of switch on top of it. It will have off pilot and on in raised letters on top of it. Now move the knob to pilot position and if you have a long lighter or maybe fireplace match something long enough to reach back into the unit about 10 inches or so. Depress the knob hold down reach back with lite match, lighter and get close to pilot and there it will lite. Hold knob down for about 30 seconds and let go. Did the pilot stay on? Good if it did. Turn the knob to the on position and go to the thermostat and turn on the furnace. Now if you are nervous about lighting the pilot light you could call the gas company in your area and explain your situation and they should come out and do it for free. let me know how it turns out. ken
    Dec 17, 2008 | Heating & Cooling
    Ariston margherita wont drain and selector knob keeps turning
    Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
    You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
    Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
    DeLonghi DEFSGG24SS Gas Kitchen Range Logo
    89 people viewed this question
    Top DeLonghi Kitchen Ranges Experts
    JP Services
    JP Services
    Vitaliy Gins
    Vitaliy Gins
    Paul Bade
    Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
