Question about Toshiba E-Studio 160 All-In-One Laser Printer
Printer My printer is mis-behaving its showing on the screen the following message :call service
  • Anonymous Aug 13, 2008
    "Call Service" it's showing on screen
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    wow...that's a truly unhappy printer...is it under warranty? Does it have fresh drivers installed?
    Problem Solver:
  • 4 Answers
Pres:
0, 8 – start
Mc= 340 set
DT= 000 set
Restart
Posted on May 26, 2008
SOURCE:
On the screen of my Epson Stylus Pro 4800 InkJet Printer came a message update F/W
it's asking if you want to update firmware, firmware is the softer internal to the printer that tells it how to work / behave / communicate. this is sometimes updated by the manufacturer.
sounds like you are in the service menu...if you press the cancel buttons, or shut it down and restart the printer it should return to normal operations.
Jan 11, 2016 | Epson Stylus Pro 4800 InkJet Printer
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
My HP Laserject Printer can print out the paper, but nothing show on this paper. And then this show the message "Paper Jam carridge check." So how do i fix this?
It sounds like the drum of your printer has a problem. Try inserting a new toner to see if it behaves the same way. If it does it is the drum and your printer is gone. If not, it could've been the toner.
Jul 04, 2011 | Computers & Internet
Screen showed message that "parts
The message that you received indicates the ink pad absorbers are full and prevents the printer from running because unchecked it would leak ink everywhere including outside of the unit. To fix this you need to replace the pads with new ones and reset the counters to let machine know you have changed the pads. On top of that you must download a utility program for your model that will allow you to set up the counters so the printer will run. I strongly recommend replacing your printer especially when it is a refurbished item, even Epson feels it is better to replace.
Jan 08, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Hello I had the type of printer Aficio 2035e / 2004 E chi Show me and mis-mis is the number sc548 sril-j7952801548 "Sorry if you can not understand me because I use Google Translate" I hope...
If you remove the fuser unit without turning the power off you get this message, the copier can't detect the fuser. You need to reset the code. Simulation to get into service mode (clear all, 107), and go to sp5-810. Good luck.
Dec 02, 2010 | Ricoh Aficio SP C811DN-DL Printer
I just purchased new refill ink cartridges for my canon mp 510 all in one printer and after loading them correctly(as far as I can tell) the printer is showing me a message that says the following tanks...
Sounds to me as if the chip on the end of the cartridge is mis aligned slightly. Take them back to where you purchased them and ask them for replacements......it is your right to do so
Mar 13, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Error message says printer error see
found this on another forum. I had the same problem and this worked for the problem posted:
Found this on techsupportforum.com and it worked for me. Good Luck!
Press and HOLD all following buttons: Power, Load/Eject (I don't have this button, so I skipped this), Stop, B&W, Color. Continue to hold the buttons until "Init Eeprom" appears on the printer screen. Press Color button to clear protection counter.
The panel then told me to press the power button, I did. When it came back up, everything was fine.
Dec 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error message-"printer had any motor mis-step error"
After 8 yrs..........Get a life and new printer! Inkypete
Apr 21, 2009 | Alps MD 5000 Thermal Printer
Black lines in display and printer will not turn off with on/off button
If your printer does not function properly, or communication error messages appear when using your printer, you can remove and reinstall the printer software.
  1. Click Start®Programs or All Programs®Dell Printers®Dell AIO Printer 946.
  2. Select Uninstall Dell AIO Printer 946.
  3. Follow the instructions on the computer screen.
  4. Restart your computer.
  5. Insert the Drivers and Utilities CD, and then follow the instructions on the screen.
If the installation screen does not appear:
    1. In Windows XP, click Start®My Computer.
In Windows 2000, double-click My Computer from your desktop.
    1. Double-click the CD-ROM drive icon, and then double-click setup.exe.
    2. When the printer software installation screen appears, click Personal Installation or Network Installation.
    3. Follow the instructions on your screen to complete the installation.
      If the problem continues, the printer needs to be serviced.
Aug 09, 2008 | Dell 946 All-In-One InkJet Printer
Toshiba E-Studio 160 All-In-One Laser Printer Logo
71 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
