Question about HP Pavilion m7480n (882780389410) PC Desktop
Removing hard drive
I need to change the hard drive in a Pavilion m7480n. I can't figure out how to remove it from the chassis. Any help would be appreciated.
  • 41 Answers
Please see attached documnet to remove HDD
http://h10032.www1.hp.com/ctg/Manual/c00455297.pdf
Posted on Mar 25, 2008
Hp pavilion power button removal
ok take off both side panels at the front inside you will see 3 plastic lugs on each side push them to release the front panel there you have access to the the power button.
Jan 26, 2014 | HP Pavilion Media Center TV m7480n...
I am getting Disk Boot Failure Insert system disk and press enter
looks like the software installed on your hard drive has been damaged
if you have recovery disk, try booting from it and try to repair windows. if you have valuable data on the hard drive, have a technician connect the drive to another working computer to copy the contents.
the technician may have to reformat and reinstall the window operating system and drivers for your computer.
hope the above helps. good luck.
Jul 06, 2011 | HP Pavilion m7480n (882780389410) PC...
"HP Pavilion m7580" is not
To verify whether it's a no POST issue, press NUM LOCK or CAPS LOCK key and check whether the CAPS LOCK or NUM LOCK lights are lit or changes when you press on it. If it doesn't then it's a No POST problem.
However, if the computer screen shows the HP logo or a display then it's POSTING and is experiencing a No BOOT issue.
If the NUM LOCK or CAPS LOCK responds when you press it but there is no display, check the connection between the monitor and the CHASSIS or CPU.
If you have verified that it's a No POST issue because CAPS lock is not responding, you need to open up the chassis to do a troubleshooting procedure. Be sure to unplug the chassis to all the connections especially the power cord. Drain the power by pressing and holding the power button from 8-10 seconds.
Here are the things that you need to do after you open up the chassis.
1. Reset the Memory sticks. Connect the CHassis to the power and monitor. If no go, try turning on the computer without the memory sticks. The aim of this troubleshooting is to see a display on the screen. Any display would be a good sign. If no go. Put the memory stick back in.
2. Remove the CD drive. Turn on the computer, check for development. If no go, proceed to step 3. Just leave the cd drive removed
3. Do the same thing with the other devices like the hard drive and other devices inside. Your aim is to see a display.
Let me know if what happens and I'll get back to you.
Once you see a display. Let me know by replying to this thread.
Apr 07, 2011 | HP Pavilion m7580n PC Desktop
I have a 2005 Hewlett Packard Pavilion m7480n (882780389410) PC Desktop i've tried numerous things on it to fix it but nothing seems to be working.. i disconnected everything one by one and then all at the...
Here is something to try that might fix you up.
Dry boot is a way to reset HP laptops. Sometimes it works and sometimes not. Here is how to do it.
Disconnect the power cord, remove the battery, press and hold the power button for about a minute. Then re-insert the battery and power cord and try to turn it back on again.
If you are still having the same issue, remove the battery but leave the power cord and try to turn it on. Oh yeah, disconnect any USB devices and a monitor (if you connected a monitor to your laptop), make sure there is no disc in the drive either.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | HP Pavilion m7480n (882780389410) PC...
I have a HP pavilion m7480 that Im having problems with. It started with it not booting, just having a black screen. I took out the ram, blew it off, reinserted it and it booted up, windows started, but...
i looks like you are working with the wrong part the problem here seems to be the hard drive and not the ram.
i believe the hard drive is damaged and needs replacement if you can move the hdd and connect it to another computer as slave would see it it is working or not
Aug 27, 2010 | HP Pavilion m7480n (882780389410) PC...
How can I install an additional hard disk to the
I would like to come and help you but you probabably live too far away. So I would go to web site of the manufactuor or your computer and ask how do you remove the drive bay to add anothre drive. Most companies will give you a downlpad to a pdf so you can see step by step on how to do it...Good Luck,,,,Darren
Oct 11, 2009 | HP Pavilion Media Center m9340f Desktop PC
How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Nov 03, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Removing the hard drive
yes..you have to open up the chassis, and remove the skins around it to access those screws..
Apr 28, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
HP Pavilion DVD drive replacement Vista
not too difficult
remove side panel of pavilion
tabs inside of chassis, near front of unit, press in gently. There are two or three of them
remove front panel from chassis
either remove the screws holding the dvd or use the green slider
unhook dvd from cables and power supply
slide out
reverse for installation
make sure you get new drivers from site(like this one) and resist temptation to use cd supplied
Mar 09, 2008 | Computers & Internet
HP Compaq NX9010
Yes the problem is solved. I unplugged the computer and removed the battery for a couple minutes. Then replugged in everything and it is working fine. Go figure.
Feb 20, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Pavilion m7480n (882780389410) PC Desktop Logo
256 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
