Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
My XT will drop out and say"antenna" in my boombox and my car. If I squeeze it into the socket very hard it will come back in. It may work for an hour and then drop out--even with no external movement in the boombox. I then have to push down very hard to get it to come back in. I will not buy another one.
