Trying to help a friend. Unit was not emitting ozone, and fan was very sluggish. Replaced fan and cleaned lint filter. It now runs properly. Ozone plate didn't look dirty but did have a dark spot where contact touches plate. Replaced plate with new plate. Still no ozone. Took plate back out and turned unit on as directed in manuel, checking for Prove-it light. No light with fan running and ozone control set at 12 o'clock as directed. Also the ion indicator lamp does not light. I'm usually pretty good at following directions if you can tell me where to go from there. Thanks for your help.
-   My XL-15 had the same problem a couple of years ago. Turned out to be a problem with the power supply, I had to send it in to have it fixed. works great now. -   cant standit
Apr 27, 2008
-   The unit isn't making ozone, even with new plates. Now what?-   Guest
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
