Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Tried to upgrade my hp from windows 98 to xp now it wont come on. It beeps then the monitor goes to sleep.Can not even run my redtore disc.
  • Palmbeach
    Palmbeach May 11, 2010
    Sorry you're having difficulty.
    How have you installed XP?
    Do you have a full install disc?
    Did you format and partition your hard drive first?
    Did you get any error codes during the installation?
  • 869 Answers
At start up of computer start tapping the f-2 key until you open the bios.In the bios change your drive order so that the computer boots first to CD-rom.
Posted on May 26, 2008
6ya staff
SOURCE:
MY HP MONITOR 2159 WONT POWER UP
have you tried other cables and outlets? if so, hate to say the capcitors are blown inside and it needs to be replaced. when you do get new panel, always turn it off when your not at your pc. even so it goes to sleep, there is still a current running through the capacitors because when you move the mouse it wakes up. these capacitor have like a 0000-40000- hour life span.
should have asked, do you get a light? is the vga cable plugged into pc?
if this helps please take time to rate
Feb 01, 2013 | HP 2159M Monitor
I have upgraded my compaq armada e500, it has all the requirements to upgrade from windows 98 to windows xp. i tried to install a fresh copy of xp, the set up stops in the middle. i tried several times...
We check of the requirements of you loptop to isntall a windows Xp so we determine that windows xp you installed is not a genuine..
maybe the OS that you installed is not a genuine so you cannot install .it.try to install a genuine OS
Aug 31, 2011 | Compaq Armada E500 Notebook
My new L1940T (hp) monitor is stuck in sleep mode. At boot, green light illuminates, then goes orange. Window opens saying 'going to sleep mode' then completely unresponsive. Tried everything; moving and...
We need to narrow down to find out if it is your PC is not sending the video signal to the monitor or the monitor itself is bad, you need to try this monitor with another PC or try this PC with another monitor. Please post back what you find after trying the suggestions.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Aug 26, 2010 | HP L1940T 19" LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
My hp w2207h goes to sleep
Sounds like your video card is failing. If the video is internal to the motherboard, get a video card and add it to the motherboard if there is an open video slot available
Mar 13, 2017 | HP Computers & Internet
My monitor goes to sleep mode at startup & can't access safe mode
Turn the computer off, open the case and remove the RAM. Does the computer beep when you turn it on with no RAM? If not, your motherboard is dead.
If your computer beeps, turn it off again and try putting one stick of RAM in. If the computer doesn't turn on normally, try the other stick of RAM.
Also, try taking out the video card and putting it back in.
Good luck,
Jason
Jan 25, 2009 | E-Machines eMachines Desktop PC
Monitor goes to sleep and computer will not boot
If your monitor goes to sleep, how do you know it got to window xp screen ?
Sound like your stuck in a loop (bad boot sector). You might have to reinstall windows again.
May 06, 2008 | Computers & Internet
Open Questions:
See all HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Questions
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
