Question about Mercury P4VM800M7 Motherboard
Replaced motherboard Hi i bought a second hand computer and it was really dirty so i removed all the bits but left the wire and leads attached but when i came to put them back my daughter bliss her had removed all the wires cause she wanted to help .........now i dont know what go wear as this comp is second hand i have no manual please please help me thanks
  • 1 more comment
  • Anonymous Aug 26, 2008
    Lan Not Working Properly
    Kolkata Service Center Ph No -------Please
    [email protected]
  • Anonymous Aug 29, 2008
    i need to reconnect my motherboard
  • Anonymous May 11, 2010
    Most motherboards have written on the the mother board next to the double row of pins what they are, you will need bright lites or a flashlight and depending on how good your eyes are you may need a magnifying glass. psw or pwrsw=power, rst or rsw=reset, hdd led, hard drive led, pwled=power led. if the header from your front panel wires are not listed you may have to trace the power button down to find the correct wire.
    If the info is not there, written on the board is usually a manufacturer part# or board #. sy-XXXX, ms-XXXX etc.
    Id can also be made by chipsets, northbridge and southbridge
    VIA, Intel etc, and the #'s
  • 807 Answers
If you can find out the make and model number of the motherboard inside you can look on the net for the manual (or let me know and I will look for you), which tells you where everything goes. The make and model number is usually printed on the board.
Posted on Mar 18, 2008
SOURCE:
A week ago, pc would not start up. Removed all the psu cables connected to my hardware devices, pc still would not power up. Checked around retail stores for a good psu, bought Antec 650w psu. The A8N-SLI ...
the beeps a post make sure you ram modules are securely seated
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Sep 02, 2011 | ASUS A8N-SLI Motherboard
Sound but not picture
this might be caused by a faulty lead or a dirty graphics card
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your: "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jul 07, 2011 | Computers & Internet
If i un plug the montor on my pc it says check the white blue red wires .if i plug it back in screen gos black
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty:
hope this helps
Jul 04, 2011 | Computers & Internet
Hi, My Motherboard is intel dg31pr which has the problem of "THERE IS BEEP SOUND AND NO DISPLAY BUT THE CPU FAN IS SPINNING" Please give me a solution Thanks in advance by Ibrahim
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
:hope this helps:
Jul 03, 2011 | Intel DG31PR Motherboard
I have an HP VP17 Monitor. When I plug it into power or the VGA connector the screen will show for about 1 second and then the screen goes black. Any suggestions?
Test the PSU if the units fan is not working the power supply unit is faulty
hope this helps
Jun 15, 2011 | Computers & Internet
Just bought a system. It boots but no video. Removed video card, tried onboard still no video.
if you mean that you cant get your screen
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
May 19, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
Monitor only comes on 4 a second then goes black. clear picture when it does
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
hope this helps
May 12, 2011 | Computers & Internet
My computer turns on just fine then it says input analog and the my screen gos white,but if i hit the imput button on the side of my monitor it will flash back but you can only see the picture for a split...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
Apr 30, 2011 | Computers & Internet
Signal to monitor lasts for about 20 seconds then stops (initial installation of pci-e card). Neither new graphics port or onboard port works after 20 seconds
Apr 20, 2011 | MSI R5450-MD1GD3H/LP RADEON HD 5450, (1...
At booting time the computer give error " CPU over temprature error" why it is? The second problem is when I start my computer it restart automatically after 4 or 5 second but when lay down it...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 25, 2011 | ASUS P5PE-VM Motherboard
Mercury P4VM800M7 Motherboard Logo
57 people viewed this question
Top Mercury Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Gustavo Ortiz
Gustavo Ortiz
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
