Question about Tissot T-Touch T33759851
The touch screen dont work
When Ipress the button to activate the srceen nothing
  • psherwin Nov 17, 2008
    The touch goes straight to (faulty) altimeter and will not accept any other function. It bounces straight back to altimeter. Cannot get digital time or date - touching centre of watch does nothing.
Hold the button until you hear a beep. then press on the glass. if not, return it.
Posted on Jun 20, 2008
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
Setting the time on the PU910222003 Puma ladies watch.
The process may be less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
The process is actually less complicated than you would think.
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
Jun 30, 2009 | Tissot T-Touch T33159851 Wrist Watch
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
Jun 04, 2009 | Tissot T-Touch T33759851
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
User Manual Nixon Lodown Tide Watch
hello... my nixon dont work... the screen went completely black and does not work any buttons....
I can do??
sanks Daniel
Apr 13, 2009 | Nixon Lodown Tide watch
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33759851 Logo
162 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
