Question about E-Machines eMachines Desktop PC
I cleaned my cpu and now when I turn it on it beeps
I took the fan out of my emachine t5620 and cleaned the dust out of it. I dropped the screwdriver I was using inside it. When I plugged it back in it started beeping. The fan works and the light comes on but nothing else except the beep. What did I mess up?
  • shaymonu Mar 18, 2008
    I forgot to add that I had the case on it's side and dropped the screwdriver on the motherboard. I have switched the two memory cards around and all the commections appear to be secure. Thank you very much for trying to help me!
    Problem Solver:
  • 18 Answers
Check how the beeps go because they sound in a certain order according to what problem their is with the computer try looking up beep diagostics for that motherboard see if that is any help. Have you also checked to see if the video card is inserted properly if you have one. Do you know exactly where the screwdriver hit on the motherboard. If the problem cant be solved then you may be better off getting or trying another motherboard. Hope this has helped in anyway. thanks
Pconline-Fix
lee
Posted on Mar 18, 2008
    Genius:
  • 1,027 Answers
Ram memory usually causes the beep, check first to see if all modules are secure,
My laptop powers on and right back off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 26, 2013 | E-Machines Computers & Internet
Emachines t5234
Nov 27, 2012 | E-Machines eMachines Desktop PC
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
I'm the one with the emachine that won't boot just beeps resat RAM and repluged video.
check FAN on CPU. Check also the radiator on the CPU. If you can - remove CPU and check the paste between the CPU and radiator - apply new paste, assemble back the CPU and try again.
Feb 28, 2012 | Computers & Internet
So I have a Emachine t2984 model... It was working perfectly till out of nowhere I heard two beeping sounds coming out the computer then CPU shut completely off. So I went to tried to turn it back on but...
you have done the right thing by cleaning the dust from your computers fans you should continue cleaning the dust from your computer as dust will cause static which can cause a computer lots of unforseen problems
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps keep up the good work
Mar 28, 2011 | E-Machines Computers & Internet
Got a screen message that fan is not working. Now when I turn on the computer it just beeps at me. What do I need to do to solve this problem?
Open cover and switch it on, check if fans turn (assume CPU fan), if not switch it off and remove from mains, replace faulty fan or clean the fan with a small brush and vacuum cleaner might be clogged with dust. If this fails check bios settings for CPU temperature and adjust accordingly, do not exceed recommended CPU temperature, or CPU will overheat and eventually be destroyed.
Computer shuts down and beeps due to over heating and bios shuts down machine as a precaution.
Jan 15, 2011 | HP Pavilion m7650n (RF254AA) PC Desktop
I have an emachine t5026 that won't turn on. It sounds like a car tying to start and the lights on the front flash as does the light on the mouse, but it won't start
check the fans on inside of the computer. they may be all gummed up with dust and lint. clean carefully and try and turn it on again. also watch the fans and see if you can tell where the bad sound is coming from, if the CPU fan is clogged up the CPU will over heat as its turning on and shut down.. if the raunchy sound is coming out of the power supply then that may be bad. sounds as if it might be.
May 08, 2010 | E-Machines eMachines Desktop PC
Emachine T5062 pc wont turn on, I get 5 beeps When the computer performs the ''Power on system test''. I could not remember what BIOS the computer had but I think It was AMI. The five beeps for AMI mean...
make sure it is not getting really hot, also try cleaning all again and start putting them together step by step. make sure the dust didn't got in another part like RAM memories slots, and if you have a big problem with the processor the PC wouldn't even start, wont even turn on.
Nov 15, 2009 | E-Machines eMachines Desktop PC
Emachine t5230 cpu fan too fast
Hi orinzelenak,
This may seem like to simple, but try checking to see if the technician plugged the fan power supply into the correct pin for it. It sounds like the fan is plugged into a external plug directly from the power supply and not into the board, which would control the fan speed for you. Give a look, and maybe it's just that simple.
Good Luck
Mark
Jan 04, 2009 | E-Machines T2682 (000002965) PC Desktop
My Emachine Fan Way to Loud
... this may be worth a try; it worked for my noisy emachine fan.
First open the box and vacuum out any dust on the fan. I also opened my power supply and did the same; there was quite a bit of dust, so you can imagine the heat never got the chance to be removed. Also, on my machine, underneath the CPU fan, there's a metal baffle; get the dust out of this as well ... same problem re. removing the heat. Last... and I'm not sure this matters or is true, but, for my fan, the power supply plug on the motherboard seemed to accept the plug oriented 180 degrees different from the way it was plugged in from the factory ... could this change the direction the fan blows? It certainly explains the bizarre build-up of dust in my CPU baffle. Once I did this, the fan goes up to 100 percent for about 3 seconds on boot, then it has never 'noised-up' like it used to! ... it's totally quiet now and the computer works great...
good luck
Dec 20, 2008 | E-Machines eMachines T3830 PC Desktop
E-Machines eMachines Desktop PC Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
