LCD screen removal & assembly
Hi!
I knocked my Microteck LCD Monitor off the desk resulting in a circuit board of some kind to come out of the case.
It is still attached and the monitor is still working but has some broken mounting brackets. The screens frame came off , all except one corner. I am not sure on how to remove it completely. I am not sure how the board was attached but once I can gain access it may be apparent.
Does anyone know how the screen is disassembled and reassembly?
Thank you,
Rick Jones
    Novelist:
  • 138 Answers
If you can post the image of your monitor here, it would be great. Actually, I used to repair monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
Thank you,
Posted on Mar 18, 2008
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Tv is dim and can't brighten
Apr 28, 2017 | Televison & Video
I have a VIZIO 60 inch tv with problems on the screen, the right side does not see the image and on the left side if, who can ?? it has a solution??
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Apr 26, 2017 | Vizio Televison & Video
I have an Element tv that has no picture, good sound but basicaly a black screen. Do i need a didgital board or a main board?
Apr 26, 2017 | Element Televison & Video
I have a lg55la6200 led/lcd smart TV. When I turn it on it stays on for about 15mins and then the screen turns off but sound still on. I have done the flashlight test and can see the picture.
Apr 22, 2017 | Televison & Video
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Hi Help desk, My Samsung SyncMaster 540N LCD monitor is taking hours of time of display the desktop.what might be the case?Is it due to CAPACITORS popping out? Need a damn help from...
hi there,
Yes, it's capacitors issue.
I will explain how to fix it:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated
  • Replace that capacitor. Done
For More details please read my tips here
Please let me know the result
Thanks.
Dec 16, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Faulty hp en623aa flat screen monitor
my desk top is half display is ok and half display is white light & all program is look a lite
Jul 24, 2008 | Xerox XG-91D 19" LCD Monitor
Computers & Internet Logo
1,825 people viewed this question
Alun Cox
David Payne
David Payne
