Question about Bosch Axxis WTL 5400 Dryer
Bosch WTL 5400 running, but not heating
The dryer seems to be fluff drying everything. No heat is coming into the drum. All filters were cleaned thoroughly. Is there anything I can do to attempt to correct the problem before calling in the professionals?
Thanks,
Mey
  • Ben Swire Apr 09, 2008
    I'm having the same problem!
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Posted on Jul 18, 2008
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Bosch wtl 5100 - spins but doesn't create a hot air flow.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 02, 2010 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Filter lamp flashing
The condenser has two "channels" one for the moist hot air that are easy to clean and inspect. The other flow is perpendicular where cool air drawn from outside and passes through. These channels, viewed from the side can get blocked over time with dust/fluff. I blasted mine with a pressure washer and it was obvious from the change in light when looking through it that it was clogged before I blasted it.
Sep 18, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Moister
Does the fan works properly?
Oct 31, 2006 | Bosch Axxis WTL 5400 Dryer
Dryers Logo
653 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
