Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Numark cdx my cdx unit is distorting and sounds like an old piece of vinyl playing rather than a cd, i have replaced the drive with a new one but the problem is still there
  • 4 more comments
  • Daan Snouck Jun 02, 2008
    I have the same problem. I use my CDX a lot for scratching during live shows en after a certain time the sound just gets F-ed up. Indeed, like an old worn down record, with pops and hisses and everything. When I change the CD it's back to normal again, but only for a short time. And only if the drive reads the CD.
    My guess it's because of the heat it builds up, but it could be anything, from the b-grade cd drive in the CDX to the type of CD-r's I'm using.
    Just to top it off, here are my list of defects/faults I run into while using the CDX:
    - really bad sound after a while
    - CD drive won't read some CD's, wether official or burnt CD's
    - Sometimes ejects CD's after insertion, for no apparent reason and it isn't consistent: it might accept a CD it rejected 4 times earlier.
    - it takes a long time just to read a CD, which shouldn't be the case with a machine like this. It should be like changing a record on your turntable: a matter of seconds.
    - The BPM button-mechanism is way too loose so the button gets stuck a lot when pressing it for BPM measuring
    Besides the last problem (which isn't really a problem, just a minor inconvenience) I must conclude it all comes down to the CD drive.
    Which is a shame really, cuz Numark still have the only machine like this out there and I'd hate to have to denounce the whole brand for choosing the cheap way out with the cd drive.
  • felix_mf Jul 09, 2008
    my cdx unit is distorting and sounds like an old piece of vinyl too and some time it dont want read some disc
  • Anonymous Jul 16, 2008
    i have the same problem, i'm a dj in Ibiza (spain). as the unit heats up it becomes more of a problem, i often use the cdx with timecode cd's for numark virtual vynal and it causes serious problems with the software when it does start to go. what i have noticed, if you turn off the unit, turn it back on, and mess about with the pitch slider and effects, it tends to last longer before it goes bad again.
  • Anonymous Oct 08, 2008
    I feel this is a bunch of BS. I spent my hard earned money on these turntable and this is what I get I am not happy. It seems to me that numark knew that this would be an issue.
  • Anonymous Oct 22, 2008
    Same Problem...
  • Anonymous Nov 22, 2008
    same problem cdx sucks
I have all the same problems as the person above. and it makes me want to throw them in the garbage.
Posted on Oct 01, 2008
My cdx sounds really terrible
hello
faced the same pb only with MP3s audio tunes burnt on cds (crackles..pops ect ) - no prob with normal cds
Nov 23, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Cdx doesnt read any cd.....
Numark has yet fix this issue. You will need a replacement CD drive, they swap right out. Their warehouse is located in Cumberland RI (US). Unless you could score one on ebay. I have about 3 of them, you interested?
Mar 20, 2008 | Numark CDX Turntable
Numark cdx
I'm sorry to tell you this, but my advice would be to buy a pair of Pioneer CDJ-800s or CDJ-1000s
I can't see the 800s costing you much more that what paid for the Numarks, and there's a reason why the Pioneers are used extensively in nightclubs, and the Numarks aren't.
Mar 20, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Not reading any cd's
they are known for this! Does it take cd in for a few seconds and spit out? Does it take cd in and just tick? (if you put ur ear up to the drive you'll actually hear it try to spin but just give a lil tick noise). Numark does sell a replacement cd drive which isnt exactly a 100% fix but worth a shot seeing how the unit cost quite a bit. If you do end up replacing the cd drive and does not fix your problem there is also an internal cable. Once you pull out the drive, look inside to the left you'll see a white flex cable which may need to be re-seated. Let me know how you make out!
~digitalscorpion
Jan 15, 2008 | Numark CDX Turntable
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Numark cdx
Hi, i would try using different cdr recordable media or try a different burner if this dosent help then i would say your laser is at fault or in some cases i have had the servo pcb going faulty on this model. hope this helps. regards. paul.
Sep 02, 2007 | Nu Mark Numark Cdx Table Top CD Player CD...
My Numark CDX Cd drive wont open, but it will still play..
If you haven't sent it in the You see the four screws Were You put the Cd in at? Take them Out... then There is two tab on the bottom where you pull the drive out but be careful when taking apart
Nov 04, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
339 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
