Question about Brother IntelliFax-2820 Laser Fax
Fax busy, no response yet fax is sent ok
TRIED TO FAX 16 PAGES. GOT BACK MESSAGE "BUSY, NO RESPONSE".
FAXED AGAIN AND GOT SAME MESSAGE. I CALLED TO LET THEM KNOW AND WAS TOLD THAT THEY HAD
RECEIVED BOTH FAXES - 32 PAGES IN ALL.
  • Anonymous Jun 24, 2008
    sending a fax when transmission verfication report says busy/no response
  • Anonymous Nov 12, 2008
    fax always says busy no response
    Problem Solver:
  • 9 Answers
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Posted on Nov 19, 2008
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
Cant receive fax
FIRST OFF. IF YOU PLUG A PHONE INTO THE JACK DO YOU GET DIAL TONE? IS THE WALL JACK PLUGGED IN TO THE RIGHT JACK ON THE MACHINE? NEXT GO IN TO THE MENUE SET UP FOR FAX. GO TO THE SECTION WHERE YOU WILL SEE EASY RECEIVE AND EASY SEND, ON BOTH OF THEASE PRESS SET OR OK THIS SHOULD NORMALLY DO THE TRICK, IF ALL FAILS, THEN YOU MAY NEED A PHONE BOARD CALLED A NCU BOARD. GOOD LUCK BROTHER SR TECH
Jan 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Beeping sound when try to fax. report says busy/no response
hi,
check it out weather it is in fax mode not in phone mode
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
"poor line condition'
Very often this is caused by either the sender or receiver having VOIP phone service. Check this and if this is the case you need to set the baud rate to 9600.
Hope this helps!
Jun 09, 2008 | Brother MFC-8840D All-In-One Laser Printer
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
Can't send out fax
Make sure the phone cord is connected to fax machine in the place marked LINE, then make sure the phone cord is connected to the wall jack. Pick up your handset and make sure you have a clear dial tone also. If you are dialing long distance make sure you have the long distance service.
Nov 09, 2007 | Brother IntelliFAX 1840C Plain Paper...
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFax-2820 Laser Fax Logo
2,555 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
