Question about Sharp AL-1655CS Laser Printer
Mechanical problem As soon as i close the side cover, i can hear a loud noise, which sounds like a non-engaging gear. I initially thought it might be related to the drum. So, I removed the drum only and put back the cartridge before i close the front cover, followed by the side cover. As soon as i close the side cover again, i can hear the exact loud noise again. I even tried different cartridges and drums, but in vain. I would appreciate if anyone can help me out. Thank you
  • Kenny Chung Mar 18, 2008
    Will replacing the fuser fix the problem?
  • brian c
    brian c May 11, 2010
    Sounds like its a fuser drive gear problem.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Kenny, It is the fuser and maybe even the fuser drive gear.
Posted on Mar 18, 2008
Loud noise when auger is engaged on 2 stage 24" 208cc
If this is covered with a warren tee I would take it back where I bought it. Sounds like a faulty bearing or something is sprung and hitting when it starts up.
Feb 08, 2014 | Yard Machines 24" 208cc Two Stage Snow...
In the beginning of 2010 my 2007 GMC Envoy started making a really loud whining noise coming from the driver side of the engine in the front. the car runs fine I still drive it but it is getting louder. I...
Could be the start of a transmission problem.
GM had a ton of recalls from 2004-2010 on their transmissions.
aside from the worst case.
Ask your mechanic friend if you have a "fan clutch" and the test is simple. When you shut off the engine, does the fan continue to spin for a short time?
I have run into a few that had faulty fan clutches. If you hear it when shifting gears, that leans toward the transmission, but related, and also a recall from GM is the driveshaft.
You can call the service department at any GM dealer, ask for a service drive person, then have your VIN number handy as you ask them to do a search for recalls for your vehicle.
Hope you get it sorted out.
I am a former GM mechanic.
Dec 07, 2012 | Cars & Trucks
1998 dodge grand caravan. The doors lock automatically when you begin to drive. They make a loud grinding noise when this happens. The locks still work but it make the sound when you lock or unlock the...
That sound is going to be your door lock motors wearing out. I would suggest getting them replaced pretty quickly as they will soon stop locking altogether. It's not cheap, but it isn't horribly expensive either.
Mar 05, 2011 | 1998 Dodge Caravan
My xerox machine is making really loud funny noise that are unusual, it makes the noise while it is warming up and until it prints, it is out of the ordernary sounds that we hear from it. it is more of a...
could be a few things... take out the drum and make sure the toner is put back in. then keep the right side door open and push the silver metal flap down near the back of the door opening (its the interlock that tells the machine the right side door is closed) and see if the noise occurs. if it does then you no its not the drum. so u can reinstall it. try to pin point the source of the sound with the right side door open. could be one of the many gears in back or the fuser (which is above the green colored drum) 4 screws and one wire harness takes off the fuser and u can physically inspect to see if the gears are missing any teeth or the bushings are broken. if all looks well then reinstall turn machine around and take off the back cover (6 screws) wiggle it off and turn the machine on and look closely at all the gears on the left(looking at the back) top side. when it starts it warm up process check to see if any gears are making the sound or cracked. if those gears are shot u mught need a new main drive assembly which is really difficult and time consuming to repair.
Jan 17, 2011 | Xerox WorkCenter 4150 Black and White...
I have a stock '02 RSX-S with 93K miles.I recently started hearing a ticking sound coming from the engine while accelerating at low rpm's in any gear (i can hear it at higher rpm's too, but at that point...
Sounds like an Exhaust Manifold leak on only one cylinder. The Gasket is probably blown out. Check around where manifold is bolted to the engine. Any leaks are usually evident by a black sooty deposit.
Jul 30, 2010 | 2002 Acura RSX
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Rattle from front end
hard to help with out hearing for my self, try getting different opinions from 2 other shop. may be worth it. 1 to be a transmission shop if it is a trans problem.
Aug 12, 2009 | 2005 Ford F-150
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Loud clanking noise in gear if the clutch is not engaged
Almost sounds like a throwout bearing problem. Either way, bring the car back and make them fix it. It will be covered under the warranty so dont let them try to convince you otherwise.
May 28, 2009 | 2009 Toyota Corolla
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Sharp AL-1655CS Laser Printer Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
