Compaq Presario CQ60-220US PC Laptop Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to format the hard drive using vista
In need of formatting the hard drive using vista, please explain how
Informat Enterprising
Level 2:
  • Expert 153 Answers
  • Posted on Apr 10, 2010
Expert
Level 2:
Answers
153
Questions
0
Helped
19765
Points
408
Ok follow this steps now. 0. Configure your BIOS and select DVD/CD ROM Drive, SATA or IDE for the first booting of the system. 1. you should have CD/DVD ROM SATA or IDE. Any of it you can use for the operations, and it's should be attach on you system unit. 2. When you are done on step 1. You can now Enter the Vista DVD/CD Disk Installer inside the CD/DVD ROM SATA or IDE. 3 Restart your system unit to proceed to the operation. 4. Automatically the system will launch the Operating System Files and it will Record all your information inside your hard disk.
5answers
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
tip
How to format Hard drive/flash drive
This is a tip explaining step by step how to format your Hard drive. This is as easy as 1 - 2 -3, so lets get the ball rolling.
Firstly, you need to know that this method can also be used with Flash drives, MP3 players, basically any removable drive.
If the drive you would like to follow is a internal Hard drive, and you would like to format it to NTFS format, here is how we do it. Remember, that you will not be able to format your C(System) drive, because, then you will delete your operating system, hence, all other drives can be formatted.
Open "My Computer" and follow these steps:
The drive shown above is your C(System) drive, If you want to format this drive, you will need to do this when you attempt a clean install of windows.
Say you want to format your flash drive, insert the flash drive into your USB port, and open "My Computer". My flashdrive is Labeled Lexar(H)
Now just follow these steps.
Now you are done, the drive has been formatted. Remember, this also works on internal Hard drives, but not your system drive.
Hope you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
on Feb 28, 2010 • Computers & Internet
1helpful
3answers
If I format the drive/erase, will I loose all the files I was able to save there? I can't copy my iPhoto onto my Iomega because it says "cannot be modified." If I format, will I lose all the...
if you format the drive you will loose all the data on the drive. save the file on a different computer before you format it. later you can transfer them back. (please rate me if this helps Thank you)
Unable to access safe mode using f8 or msconfig because a virus has exe,
try to scan ur system using your anti-virus or if still not work you need to reset it to its factory default or reformatting your HDD...
How to Format a Computer with Windows Vista
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
To format your hard disk during Windows Vista installation, you'll need to start, or boot, your computer using the Windows Vista installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows Vista installation disc, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, follow any instructions that are displayed, and then click Install now.
    • If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start Windows from a CD or DVD.
  5. On the Get important updates for installation page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.
  6. On the Type your product key for activation page, do one of the following:
    • If you are reinstalling Windows Vista, you should enter your product key now.
    • If you are not reinstalling Windows Vista, you can skip this step.
  7. On the Please read the license terms page, if you accept the license terms, click I accept the license terms.
  8. On the Which type of installation do you want? page, click Custom.
  9. On the Where do you want to install Windows? page, click Drive options (advanced).
  10. Click the partition that you want to format and click Format
    • If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format
  11. When you've finished formatting, click Next.
  12. Follow the instructions to finish installing Windows Vista, which include naming your computer and setting up an initial user account.
    • If you do not want to reinstall Windows Vista, you can cancel the installation at this point and keep your newly formatted drives.
How do i change the format from mac to vista
You will need to boot from Vista DVD then choose custom install. Now when prompted delete the partition and format it and Vista should load no problems. Please dont forget to vote
Maxtor hard drive format error
Yes, in vista you need to expand the volume. To do this you will need some guidance. A good site with pictorials so you can see the screen shots of what to do is http://www.bleepingcomputer.com/tutorials/tutorial133.html
How to install windows vista
When you boot off the Vista CD and run the setup program it will ask if you which partition do you want to use as the installation partition.
setup then will automatically format it during the install process.
Here is a guide to help you:
http://www.petri.co.il/install_windows_vista.htm
2answers
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
4answers
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to...
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
