Question about Brother DCP-7020 All-In-One Laser Printer
Brother dcp-7020 can't scan and get cc027 error
I have never been able to scan. prints ok even though the brother diagnostics say 'failed'. did previously get cc031. downloaded patch from brother and now have cc027.
i have reimaged my pc so i know there is no 'residual' registry entries or 'bad' dll's. loaded drivers from scratch.
tried using cd that came with the printer and also downloaded drivers from brother. in fact i had worse problems when i used the download wizard from brother so i went back to the cd that came with the printer. i did see wqhl drivers on the brother site and i downloaded them. but i can't get them recognized when i try to install those drivers instead.
confused? i sure am.
scan button on the 7020 just says 'connecting to pc' and hangs.
papersoft module does see wia and tw devices but when i hit the scan button i get a popup that says there is an error. not much help there.
  • 2 more comments
  • lerobroy Dec 07, 2008
    Running Vista. Printer will print from all sources but will not scan to file, OCR, etc... I get the CC027 error message (DCP-7020 USB cannot be found).
  • Anonymous Dec 19, 2008
    My printer prints but the scanner doesnt work. It keeps saying DCP-7020 USB cannot be found
  • Anonymous Feb 07, 2009
    my dcp-7020 doesn't scan, it says it's connecting to the pc but doesn't.
  • Anonymous Apr 27, 2009
    I had this same problem on my 7820-N: scan button said "Connecting to PC" but didn't do anything, Control Center couldn't find the printer, etc. Vitaebat's solution worked on Windows 2000 though I had to add the EnableWIA key. Printer scanning correctly now.
Ok I know how to fix this issue, this involves going into the registry editor, also only available in windows XP, so be careful!
Click START -> RUN and type in REGEDIT
Go to HKEY_LOCAL_MACHINE -> SOFTWARE -> BROTHER -> CONTROLCENTER -> (version number) -> (model number) -> DEVICEINFO
Look in the right hand window for ENABLEWIA, if the value is set to 0, set it to 1.
Reboot your computer, should be fixed!
Posted on Dec 05, 2008
  • Anna Houston
    Anna Houston May 14, 2014
    totally awesome, I have spent so long trying to find a fix for this problem and now its all working great. Why dosen't Brother post this on their website?
  • Anna Houston
    worked for my MFC 9420cn
I have given up on this device. i returned it and got a different machine from a different manufacturer and it installed with no problems at all.
so if someone was thinking of replying, thanks for thinking about this.
Posted on Mar 20, 2008
    New Friend:
1. Place doc on glass.
2. Press scan
3. use up/down arrows to get to email option
4. Press set
Machine will scan the image and automatically place it in your Pictures folder.
Posted on Nov 09, 2010
SOURCE:
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Dcp-115c usb cannot be found (CC027)
sure..some printers need to be plugged directly into wall socket for scanner to work..try that first..
Nov 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Mar 19, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother 7020 Fuser does not warm up
dcp-7020 fail to warm - how do i reset if i turned off and on already and waited 10 minutes
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 print error
when do you get this error, when scanning ,printing? are you on a network?
have you tried to unplug the printer and plug it back in and have you rebooted your pc if thats what your using to print from?
Oct 05, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
3,491 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
