I have come into possession of a Compaq Presario, 5456 tower computer, what was the basic spec of this computer please and how old will it be, will it support XP?
  • 589 Answers
Here's your system specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00031058&lc=en&cc=us&dlc=en&product=93360&lang=en
As far as running XP...
I've installed XP on slower PC's than yours, but don't expect it to be very fast at doing any memory / system intense operations. Boot up time may also be quite long.
Posted on Mar 18, 2008
SOURCE:
Will a hp vp17 monitor work on a compaq presario?
All monitors will work on any pc/mac computer.
The only concern might be how old is the monitor (low resolution) connected to a brand new computer (high resolution). But it usually auto adjust at windows boot up.
Check the VGA connector (blue) or DVI connector (white) for the monitor matching the pc tower
Feb 24, 2015 | HP vp17 Monitor
I need to know what kind of hdmi graphics card will work for a compaq presario sr1500NX
Hello there
Well verify, a few things:
1) power supply
2) space
3) dimension of your ATX tower case
4) select a HDMI video card GE force 7 or above that came with HDMI specs.
you will be ok!
Carl
May 07, 2014 | HP Compaq Presario SR1500NX (PX786AA) PC...
I want to know if it has a wireless card
Probably not. Here is the website for that computer's spec sheet.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr1120nx/1707-3118_7-30969217.html
Under specs it says:
Networking Network adapter - Integrated
That means it's hard wire connection to internet.
Feb 08, 2011 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Usb wireless adapter for Compaq Presario 5000
Most netgear adapters will work.
They're around £20 and will connect to pretty much everything =)
They work on windows, from 98 i think. So aslong as the old tower has a sort-of up to date OS then it'll connect for you :)
Hope it helps.
Ed
Mar 17, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario fan problems
the fans on a computer tower run all the time to help keep the pc cool. this is normal in a tower pc of any brand
Dec 04, 2008 | Compaq Presario Fan
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Open Questions:
Computers & Internet Logo
62 people viewed this question
Ekse
Alun Cox
