Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Faxing Long Distance
Can fax local but not long distance
    Sniper:
  • 89 Answers
Check the facsimile guide.
Additional Functions > System Settings > Communication Settings > Pin Code Access.
Turn it on as an option.
Hope this helps.
Posted on Jul 17, 2009
    Brigadier General:
  • 6,966 Answers
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
SOURCE:
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
Why is it when I am sending a long distance fax to another state I receive a code that says G3.
There are several reasons this could be happening.
  1. Does your office allow for long distance dialing and if it does, do you need to "Dial 9" or some code before dialing long distance?
  2. Have you dialed "1" before the area code?
  3. Is the area code correct?
These are the most common reasons why you would get a long distance error while faxing. Hope you find this useful.
Nov 16, 2009 | HP 1040 Plain Paper Inkjet Fax
Long distance phone card and faxing
After you have keyed in the fax number press pause 2 times then enter phone card number..
Press START
Sep 18, 2009 | Office Equipment & Supplies
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Need Sharp UX P100 Operating instructions
Go to the following link and scroll down to your model:
http://www.sharpusa.com/products/TypeManuals/0,1083,24,00.html
The line shouldn't be any trouble for local faxing.
*Please rate me :)
Mar 15, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Long distance faxing
the data sent and received during faxing is called downloading. You need to check if the cable is alright and if you need more bandwidth to fax for a long-distance. Please call to your phone service for this.
Let me know if you need further assistance from me.
Oct 06, 2008 | Dell 924 All-in-One InkJet Printer
Check out first with your Telephone services, and then since it take time for fax for a long distance so wait for 10 minute to complete a page.
Also read the useful information for setting from Dell Website:
How To send Fax
Let me know if I can assist you further.
Regards
Ellin
Oct 03, 2008 | Dell 924 All-in-One InkJet Printer
Kyocera mita long distance faxing
Kelly,
I hate to point out the obvious, but make sure your phone line has long distance service, then make sure you are dialing 1 before the long distance number. You didn't mention if you had to dial 9 to get out. If you do, you may have to enter a pause between the 9 and the 1. What model Kyocera Mita do you have? The fax kits vary by model, and I can look up any issues with your particular fax kit given the extra info. Thanks.
Bryan
Don't forget to rate your answers please.
Nov 27, 2007 | Office Equipment & Supplies
FAX
same as faxing any other document just put in prefix of the phone number you are faxing to 1 and then area code then the rest of the phone number.
Oct 31, 2007 | Canon imageCLASS D780 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
208 people viewed this question
Clive
Clive
old marine
old marine
Ekse
