Question about Garmin StreetPilot c340 GPS Receiver
The Gps won't turn on and I can't continue the setup.
  • 2 more comments
  • JorgenH Mar 18, 2008
    I have the same problem: I hit the Power button and nothing happens - after the MYGUIDE 3000 had worked for 12 monthe
  • active005
    active005 Jan 27, 2009
    when I power on device diodes emitting light on the buttons, but nothing appears on the monitor
    no USB port on the device
  • Alfie843 Mar 17, 2009
    I've had the same problem and can not power it up using USB or through the adapter. I've try resetting it and other methods. Even though it is still within warranty, I can't get through to them and the website is down!
  • Kevin Miller May 11, 2010
    What happens when you charge it from the computer? Does it show the icon with the unit and the computer tower?
    Scholar:
  • 174 Answers
Try to fully charge the device through the wall charger, takes about 4 hours, then try setting up. If this doesn't work, remove the battery, wait a couple of minutes, put it back, connect the wall charger and try again. To remove the battery you need a 2 mm allen wrench (was in the shipping box)
Posted on Jun 10, 2008
I need technical help from the tomtom techs!
Posted on Apr 22, 2008
    Problem Solver:
  • 5 Answers
It just shows in light grey on the screen that it is charging your battery. that take 10 hrs. When itr's done it says - charging complete.
Posted on Apr 08, 2008
Resized c drive, now windows won't start. How can I reinstall windows from windows disc
Hi Terrez,
  1. To reinstall windows from Windows disk Insert the disk in the drive, restart the computer and enter the BIOS setup.
  2. In BIOS setup, make the DVD Drive the first-starting device.
  3. Save and exit BIOS setup.
  4. Now the computer continues the restart. Look at the screen. When a message appears, you have only a few seconds to hit any key on the keyboard in orter to start the computer from the disk.
  5. From there, Windows setup will continue.
Feb 24, 2013 | Acer Aspire 3680-2682 Notebook
H20 gps says waiting for nmea gps serial data
Your GPS is looking for an alternative source of NMEA data and is no longer doing it itself. If it doesn't get that data it will continue to look or wait for it. We can disable this function so the GPS relies solely on the data it is receiving through its own antanae. This function can only be changed while in Advanced mode. If you're not running in advanced mode make sure you switch to advanced mode. Once there, go to your Main Menu (from map screen, hit menu twice). In that menu, go and select SYSTEM SETUP. In your System Setup menu you will see an opition, COM PORT. Select COM PORT and hit Enter. You will see three Check boxes (NMEA INPUT, NMEA GPS INPUT, NMEA OUTPUT). Make sure that none of those are checked. Once you are done, you can EXIT out of the menus. Go out and see if you can acquire a Satellite Fix.
From:http://www.bruntonoutdoor.com/support.php?category=Atlas+MNS
Feb 14, 2012 | Lowrance iFINDER H2O C GPS Receiver
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Screen stuck at home address won't continue with any route, even when I go back and manually enter other addresses, was working great for 6 months
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 18, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
When i try clicking navigation on my maxx digital gps it won't work... can you help me??
Have you selected the correct antenna in the setup area ?
Rgds
MisterMick
May 09, 2011 | GPS
The USB port on the unit is loose therefore does not make continuous contact.What can I do?
We offer a repair service for most GPS units. To setup service, please go to our web site at: http://www.ccl-la.com/blog/index.php/service-request-form/ The power jack repairs run $30 plus shipping.
I hope this helps,
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My etrex legend won´t detect any satellites.
Make sure its not stuck in simulator mode in the setup menu. then update your firmware on the device. you can get it from www.garmin.com
if that doesnt work then there is something internally wrong with it and will need to be sent in for repairs.
Aug 14, 2009 | Garmin eTrex Legend GPS Receiver
Gps model 330
-after the units have been off for awhile...they need considerable time to reconfigure the satelites
-so.....
  1. go outside with unit turned on
  2. find an open area...with a clear view of the sky...i.e. away from trees/bldgs/etc.
  3. wait...upwards of 20+ minutes...depending upon your unit
  4. it should be picking up signals continuously...and begin to calculate your location
-the above assumes that the unit has batteries, hasn't been dropped, etc.
-if that is the case....then the unit has other issues
Nov 06, 2008 | GPS
Interfacing
have you checked to make sure that your serial port is enabled in your computer bios.
to check:
some computers require you to press del while booting other esc.
the message should read somthing in the line
press ???? to enter setup
go to the advanced tab
look in IO (Input/Output) devices or somthing similar.
Make sure Com1 or UART is enabled.
If the device is enabled, then check to make sure that your cable is making a connection properly.
(May require you to open up the unit) if out of warantee
To check that the cable is connected properly on the outside contact to db9 port.
Pin 1 2 5 are used on the db 9
on the inside there is a cable with 4 wires soldered to a board which links the outside to the inside.
Connect your serial cable to the GPS, using a multimeter check continuity by holding red lead on pin 1 of db9 serial port and checking each pin for continuity. only 1 should indicate continuity, continue with pin 2 and pin5 on serial port connector.
If you are sure that there is connection between cable and GPS, check the cable from the soldered points to the GPS Board. If those are ok, then you may have a problem on the board. Would then sugest you take it in for checking.
Jul 05, 2008 | Garmin eTrex Legend GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
