Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Fdx series no picture no sound
Set makes a constant chirping sound when power is turned on.
thereis no picture or sound. serial no.v01011648
  • Anonymous Apr 16, 2008
    I have the same problem but do not understand the solution that was suggested.
    Genius:
  • 1,153 Answers
Change C603 and Q445
Posted on Mar 18, 2008
I have a philips 9p6044, and there is no picture or audio. It has power, but there is no display or sound. What can be the problem?
On that model if its making a constant chirp sound while powered on? If so then its most likely a convergence failure.
If its not chirping then the next most common failure is a power amp. Both are realtively easy DIY fixes. The website www.tvrepairkits.com has complete kits for both. Hope this helps.
Jan 28, 2013 | Philips Televison & Video
Making chirping sound. no picture
Problem most likely on middle board----High voltage deflection board--the chirp is a primitive indicator of shutdown or self defense in these sets.
Oct 30, 2012 | Televison & Video
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Red on/off indicator light never turns off
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Jul 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
