Question about Tally Genicom 4440 Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
  • 1 more comment
  • Anonymous Mar 27, 2014
    printhead removal
    how to remove printhead
    printhead removal
    Problem Solver:
  • 8 Answers
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Posted on Nov 11, 2010
Need a Windows2008r2 printer driver for TI/Genicom 8920
I am afraid the TI 8920 is a rather old model of printer, with the Texas Instruments brand or printer long discontined and with the demise of Genicom there are no Windows 2008 drivers for this printer.
You may wish to use the Generic Text only printer driver inculded within the Windows Add Printers Wizard, I do not belive there is any alternative
Dec 06, 2011 | Tally Genicom/T.I. 8920 Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Genicom 4440 is 15 years old and is used to print invoices with bar codes. The bar codes are not passing USPS regs. They are curved and were not like that years ago. Can the print head be cleaned or...
Yes to both questions. This printer has 3 print modules. you can try swapping the right side for the left side module or vise versa and see if the problem changes. if it does then you should replace the bad module.
Jan 31, 2010 | Tally Genicom 4440 Printer
Is there a driver available to make the genicom 3800 work with windows 7
Please check the Microcsoft compatability list (search it) for your answer. If the printer is listed, you are in luck, visit genicom for the Windows 7 compatable driver. If it is not listed, you still might find a driver at the manufacturer site. Make sure you get the driver for your OS.
Jan 20, 2010 | Office Equipment & Supplies
Is there a driver available to make the genicom 4840e printer work with vista?
Get the 32bit XP driver and attempt to install it using compatibility mode or you can try this 3rd party driver but no official support for Vista.
Dec 03, 2009 | Tally Genicom 4840i Printer
How do you clear print buffer on Genicom 4440XT printer?
The buffer on the 4440XT can be cleared by powering the printer OFF and then back on again.
You may however find print jobs are held in the spooler on the computer system and will simply reprint when you turn the printer back on again, you will need to check the spooler on the system also to delete any unwanted print jobs.
Nov 17, 2009 | Tally Genicom 4440 Printer
Telly 8108n driver for mac
We have the same problem - we have pulled out of storage an old g4 and are running tiger on it. It is connected to the network so we have to turn it on to print through it. it solves the problem but i am not happy with it.
Sep 29, 2009 | Office Equipment & Supplies
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Wake up from energy saver mode
the menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Jul 10, 2008 | IBM 6400 Matrix Printer
426 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Computer Links
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
