Question about Car Audio & Video
Speaker wiring for a 1993 dodge dakota
How do you know which colored speaker wire to use when installing a new head unit. all i would need is some sort of diagram, or just finding out which colored speaker wire is which.
  • nitejackal Mar 03, 2009
    i have the same problem but mine is a 94. would this still work?
  • Anonymous Mar 23, 2014
    need to know how to wire a stereo
    Brigadier General:
  • 6,966 Answers
To my knowledge a 1993 Dodge Dakota would have the below wiring arrangements for its stereo/head unit:
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground Chassis
Illumination Black/Yellow
Dimmer Orange
Left Front (+) Dark Green
Left Front (-) Blue/Orange
Right Front (+) Purple/White
Right Front (-) Brown/Blue
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
  • matakibud May 08, 2011
    OK so, all this wiring seems to match up to MY '93 dakota, but instead of a red/blue, I have a pink wire. Would this be the constant?
SOURCE:
What is order by color to airflow sensor 93:Dodge dakota 5.2'itr
Simple match up the colors of each wire but look for closely as some wires may for example be white and the other may be white with a black stripe on it. Just an example for all wires just be sure they match up with coordinating color. Good Luck.
Apr 18, 2018 | 1993 Dodge Dakota
1991 toyota carolla seca cs limited head unit wiring colour codes
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 25, 2012 | 1991 Toyota Corolla
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Dodge dakota 1993-- thewiring diagram for the speakers do not show which is positive and negative to hook up on my new jvc cd receiver . can anybody help?
use a AA battery and touch speaker wire 1wire on positive other on negative
look at speaker if cone come out or up wire to positive end is positive
if speaker cone goes in or down the wire on the negative of battery is positive
Apr 02, 2011 | Dodge Dakota Cars & Trucks
I have a Daimler-Chrysler CD player that I would like to install in a 1991 Dodge Dakota pickup. I have an idea on the on the stereo wiring info for the pickup, but I'm not sure on the wiring for the CD...
Usually the universal colors are Yellow---battery; red---accessories
Orange –illumination; black –negative; then the speaker’s white-white/blk;
Purple-pur/blk; green-grn/blk and gray – gry/blk. Blue and wht/blue are power antenna or amp turns on. That is all you need to know
Jan 03, 2010 | Car Audio & Video
Headlights sometimes cut out on a 1993 Dodge Dakota pickup
you may have a bad ground wire up by the head lights the ground spot should be with in a foot of one or the head ligghts
Aug 26, 2009 | 1993 Dodge Dakota
I had my head unit put in by a audio shop and when i got my car (1993 Saab 9000 CSE Turbo) back my rear speakers dint work so i took the head unit out(because the shop would not fix it or refund me and i...
If the rear speakers worked before your new head unit was installed, then the first question is does your new head unit have the facility to feed four speakers. Some systems will only power two speakers. The Audio Shop should have rectified the fault - you paid for the installation and as the customer you have a reasonable expectation that they would do it properly and ensure that all of the existing speakers were functioning properly. It would be worth challenging them again - if they refuse you could go to Citizen's Advice Bureaux or the nearest Trading Standards Office. Alternatively, try tracing the wires back from the rear speakers to the head unit - are the wires connected up properly... at both ends (i.e., the speaker end and the head unit).
The audio shop has probably hard wired the head unit because the sockets in the back of the head unit were not compatible with the plugs that came as standard with the car. A Haynes Manual or equivalent will give the colour codes for the various wires for the audio system.
Jun 26, 2009 | 1993 Saab 9000 Hatchback
I need the color codes for a 1993 cadillac deville stereo wire harness.. someone cutt the wires off of the original wire haness attached to the car to try and install a new head unit. now i don't know what...
If you have the time you will have to trace the wires. Using a 12vdc test light, ground one lead to chasis ground. Use other lead to test each wire to see which one has 12volts and mark it with masking tape or write down the color wire. Put it aside and turn on the ignition and find that 12volt and write ignition to that color wire. Now hat you have idenitifed the 12vdc hot and the 12volt ignition. Take a nine volt battery and put one of the remaining wires to one post on the battery, hold it on and go thru the wires until you hear which speaker pops font left or front right,etc. Just scratch the battery post DO NOT HOLD ON. This will identify which speakers are where. Be sure that you identify pairs that cause the pop for what speaker and you should be good to go. If you have any more questions please ask.
Mike
Apr 07, 2009 | Car Audio & Video
97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
Jan 18, 2009 | 1997 Dodge Dakota
I have installed a new radio in my 97 dodge dakota, all harnresses are color connected right but i have no sound.. power is on and a external speaker will play but the factory speakers connected to the...
In many cars the factory speakers are powered by an external amplifier. If this is your case you must get power to the amplifier or run new speaker wires from the head unit to the speakers. Running new wires is easier.
Car Audio & Video Logo
1,597 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
