Question about Sony KV-32FX20U 32" TV
Sony Trintron KV-32FX20U
When I switch the set on, the sound comes on immediately, but the picture takes a few minutes to appear. The colours and definition aren't good. The standby light flashes 5 times, stops, and this sequence continuously repeats. I believe this may be a common fault, but the manual doesn't give any specific information. Any ideas? Is it worth having it repaired?
  • Cheesa Mar 18, 2008
    Thank you Dan. I am happy to change components, as long as there is no too much solder work (I am very messy).
    Grateful if you could send me the compnent arts required
  • Deedubs Apr 15, 2008
    I have the same problem with my television. I would be grateful if you could let me know what parts are required
  • 4,234 Answers
This is a problem with the "AKB" circuit. There is a problem with the video signal. Are you comfortable changing parts inside the set? If so, please update this. I'll look up the specific parts for this model and post them.
Posted on Mar 18, 2008
Sony KV-32FX20U picture has a colour cast
Check its video output card [a card directly plugged on to the back of the picture tube] for any loose solder terminals. Re-solder all the suspected solder terminals there, by applying a little more solder to each points. A bad solder point can cause this type of problem.
Jan 23, 2013 | Sony KV-32FX20U 32" TV
I have a 36" Sony FD Trintron won't turn on and no sound
Have you tried unplugging it from the wall for a couple of minutes, this may reset it.
Jul 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I have a Sony Trintron KV-PG21P40. When I'm
Since the set recovers under some conditions, I would first look for poor solder connections. With a set of your vintage, it is common for some of the connections to become faulty. If you can solder, resolder any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted on your progres.
Mar 09, 2009 | Sony Televison & Video
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trintron Model # KV-27S22 Flashing screen
I got it fixed today at the TV repair shop down the street.
Nov 11, 2008 | Sony HT-DDW840 System
Sony Trintron KV-36HS500 TV color distortion
Sounds like the set is out of degausing, you will need someoen with a degausing coil to come and fix it. Should take all of 10 seconds and cost $100 or less. Let me know if you need more help.
Sep 11, 2008 | Televison & Video
I suspect you crt tube is going and is most likely not worth fixing
There are things you could do a tv service shop could rejuve your picture tube and adjust your screen voltage.
sometimes that does not work
I would start looking for another tv
thanks doctor video
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Mar 29, 2008 | Sony KV-32FX20U 32" TV
White lines
The problem here is with the vertical circuit. Most likely hte vertical IC is bad. Look for a small flat IC attached to a heat sink. It should have about 9 pins or so and be marked LA7837 or something similar. If you can solder, try resoldering the pins first. If that fails to resolve the problem, replace the IC. If you regain a picture but it appears distorted in some way, additional parts will be required. Update this with your results and we'll proceed from there.
Nov 18, 2007 | Sony KV-32FX20U 32" TV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Televison & Video Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
