Question about Yamaha RX-V992
The receiver sound shuts off
I have loved this receiver, but the receiver sound shuts off when listening music and there are some deep bass tones in the song. I can then turn on the receiver again, lower the volume and usually are ok. Any idea what could be causing this?
  • 4,234 Answers
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Dan
Posted on Mar 18, 2008
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
I just connected two sets of 901'a to Sansui G901 receiver. The sound is TINNY no bass at all. I've tried different connections and nothing seems to work. I've used two different EQ from bosse series
Either there is NO bass on the recordings (if you listen to it with headphones does it have bass?) ...OR...you've wired them out of phase. Connect only one(1) Bose 901's to just one side. Is there bass? Then connect the other side. IS there bass? If not reverse the phase (+ /- connections) and see if the bass comes back. Once that is done and there is BASS, then add the 3rd and then the 4th speaker. .Are you sure your Sansui can handle a lower than 4 ohm load???
Jun 19, 2014 | Audio Players & Recorders
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
Hello Tech, I beg your wisdom. My keyboardist and I love the Yamaha S80 but are stumped with an operational problem. The club blues internal 039 C07 patch sends an anoying ride cymbal strike with every...
I'm not familiar with this kind of keyboard, but it is almost certainly that you have 2 parts (2 instruments) layered together. In this case a bass and a cymbal. This is a feature, not a malfunction of every multitimbral keyboard. Multitimbral means you can play more than one instrument at the same time. This is good as you can create some nice fat sounds, but put the wrong instruments together and you'll have the problem you're experiencing. My suggestion is that you read what the manual says about layering or mixing parts. There you should find instructions on how to turn one of the instruments off. You can also try to google the words "how to parts layer (or sound layer, or combine sounds) on the Yamaha S80". Good luck.
Dec 16, 2009 | Yamaha Full-Size Keyboard
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
Sony's car stereos, mine the
never mind, I'll ask a friend.
Jun 22, 2008 | Car Audio & Video
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Receiver shuts off at times
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Dan
Dec 14, 2007 | Yamaha RX-V992
Yamaha RX-V992 Logo
197 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
