Question about RCA F32632SB 32" TV
  • 1,139 Answers
Hello neall,
It sounds like you may have a power supply problem- (HV Power supply). I must ask if you have sound or not? If you have sound it is the HV supply only if you do not have sound the Low Volt power supply and possibly the HV power supply/Horizontal section has a problem. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank You,
Posted on Mar 26, 2008
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
Jul 08, 2011 | RCA Televison & Video
Rca big sreen went black and white menue is still in color
Try using one of the other video input options, like AV inputs. If still have black and white picture, then the color processor is having issues. If now in color, then your tuner has issues detecting the chroma / luminance signal.
If you are using an external digital box, this may be the source of the problem as well. If you still have a VCR, connect the coax from VCR to the coax input on the TV, and play a tape. Tune the tv to channel 3 or 4. If in color, then your set top digital box is faulty.
Jun 25, 2010 | RCA Televison & Video
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
27" Zenith Television
Assuming the picture tube lights up and you have snow when selecting the tuner function, I would first hook up a working VCR with a good tape and play it while the set is on channel 3 (if that is what your VCR is set to). If no sound or picture is displayed while the tape is playing,it could indicate a defective tuner. If you don't even get snow with no antenna connected (unless your set is designed to go to a blue screen with no signal present) then you could have a problem in the video processing circuits which would explain no picture with the RCA connections as well. This would probably make the set beyone economical repair.
Sep 15, 2008 | Zenith C27A24T 27" TV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Stuck on channel 2, "No Signal" and snow
Two things may be at play here. The tv might be only programmed for reception on channel 2 and will need to be re programmed to receive other channels.
Also try some basic troubleshooting on the remotes. Start with the remote that came with the tv. Replace the batteries try the "MENU" button. If you can get into the menu try to "autoprogram" the TV
May 01, 2008 | Sony KV-36FS100 36" TV
No color, only black and white
There are no bulbs inside this set to replace. This TV set is all solid state. That means it uses transistors and IC's to work. If the color is not there you could have a bad tuner assembly in this TV set and to replace that would cost you more then the TV set is worth. Sorry. Good Luck
Jul 18, 2007 | RCA BD20TF10 20 in. TV/DVD Combo
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
