Question about Garmin Quest GPS Receiver
Quest unit not accepting map info
My qust unit is not accepting a map area when i download from p.c.I says "no map" in bottom left of screen. All i get is a blank screen with my position being tracked by gps ,but no roads or anything.
I have tried to load it several times again o no avail.
    Guru:
  • 1,894 Answers
U need a firmware update i think
Posted on Mar 21, 2008
  • dewan nafees ahmed Mar 21, 2008
    1. Click on the link below and click "GPSMAP60CSx_360.exe".
    Choose to save the file to your computer.
    http://www.gpsinformation.org/perry/gps6...
    2. Choose a location where you can easily locate the file by saving it to a location such as the "My Documents" or Desktop.
    3. Once the download is complete, locate the file and double-click on it. This will launch the Win-Zip Self Extractor.
    4. Click on the button labeled "Un-zip".
    5. Once the un-zip process is complete, click on the "Close" button to exit the Win-Zip Self Extractor.
    6. Open the C:\Garmin folder locate the file named 'Updater' and double click on it.
    7.
    You should see the name of your GPS device next to the 'USB Device'
    option on the Updater program window. Select the 'USB Device' option,
    then click on 'OK' on the Updater program window to start the data
    transfer.
    8. Once this is complete the unit's operating system will be update to the current version.
Gps nuvi it alays say no match found
Every Garmin Nuvi has a map info screen. check to make sure your Garmin has maps
usually that screen is
Tools;
Settings;
map;
mapinfo (at the bottom)
or
Settings;
Map and Vehicle;
My Maps;
If it is greyed out or a blank screen then your garmin is missing its maps. otherwise, make sure the maps are checked and make sure you are searching in the right area. by default the Garmin will search within 50 miles of you.
Aug 03, 2014 | Garmin nuvi GPS
155W Have downloaded purchased update, loaded them onto SD Card. Unit says " No detailed maps found . . ."
Have you try looking in the map area to see if it is checked...
Tools... Settings ..... Map...... on bottom of screen press Map Info
Your SD card if found should have a checkmark in it. If not put one there and try it
Nov 08, 2010 | Garmin nuvi 255W GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Won't accept address information from user
Check in Settings -> Map -> Map Info to see which map(s) currently are installed, perhaps only a small part of the region got installed. When updating map material the unit will erase all old map material from the unit, so if you had a larger area than the one you updated to, then only the newer smaller area would be installed, and thus searchable.
If you have MapSource on your PC and the new map update installed there too, you can try to search for the same address there and see if you're able to find the address then.
Jun 02, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil email pjb3103@bigpond.com
May 24, 2008 | Garmin Quest GPS Receiver
Garmin Quest
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Mar 21, 2008 | Garmin Quest GPS Receiver
Quest .No maps coming up on screen
I already suscribed,and ,no , its not fixed.The person I was assigned had less of a clue than I did.What do I actually get for my $19.99 that I sent on paypal????
Mar 16, 2008 | Garmin Quest GPS Receiver
Garmin Quest unlocking maps
i BOUGHT A QUEST ON E-BAY, WHEN I TURN IT ON AT THE BOTTOM OF THE SCREEN, " CAN NOT UNLOCK MAPS" HOW CAN i UNLOCK THIS UNIT SO I CAN PROGRAM IN CITIES AND STATES.......
Feb 06, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
