Question about HP PSC 2110 All-In-One InkJet Printer
Dirty glass What I mean is the glass on the inside of the printer is dirty... I do not see how to remove the glass to get to it to clean... Is there a way to do that.
You can remove and clean the glass by first lifting off the scanner lid. Then pry the control panel bezel off and look for a square hole toward the front of the panel. Insert a screwdriver in this hole and press down then slide the panel toward the front of the printer. It should then lift off and you'll see a ribbon cable connected. Pull it out gently and set the panel aside. There are three T10 torx screws. Two at the rear and one at the right front. Carefully lift the glass assembly up while inserting a flat screwdriver in the left front edge to seperate. Lift the glass assembly off and clean as necessary.
Posted on Aug 25, 2008
    Sergeant:
    Champion:
  • 210 Answers
oh am sorry.... no you cannot do it....
thanks and regards
agnel
Posted on Mar 19, 2008
3 Suggested Answers
flopez
  • 161 Answers
SOURCE: dirty glass
Taking that glass apart requires removal of almost all exterior covers. Not recommended to users without technical training. Any Samsung copier service center should be able to do it, since the unit is really made by Samsung as model SCX-4720f/fn.
Posted on Sep 22, 2007
agnelkj
  • 210 Answers
SOURCE: Scanning glass dirty
hi,
not to worry... u can clean it with a lint free cloth.
thanks and regards
agnel
Posted on Mar 17, 2008
Samsung scx452f when making a copy on the scan glass the copy comes out covered by a toner to dark, when making a copy on the ADF the copy comes out good. what is the problem ?
Step 1:
Good day...
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing:
- Dirty Sensor (check all the sensor)
- Dirty Glass (check all the glass)
- The cartridge is not properly installed
- Full Waste Toner section
- The corona wire is dirty or broken (Inside the cartridge)
- The transfer Unit is dirty or broken (Inside the cartridge)
- Broken gear motor connected into the drum section
- If they have developer include in this model try to check it and
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
- Broken or dirty Cleaning Blade Section
- Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
Let us know if the problem is solve.
Sorry for my english
Feb 19, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Pring blank pages
Step 1:
Good day...
Step 2:
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
Step 3:
Feb 19, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
I have a Canon CLC 4000, I have put new drums, and developers the fixing unit its OK. the glass(clean inside) too, but when i print o copy the colors are ok but a little Clear in some parts white spots...
If you haven't cleaned the optics and the coronas, do it. Always clean the machine, first. It'll save you money in the end. Not just the original glass. There are 3 optical mirrors in the optics cavity(underneath the original glass). One above the drum, and there are thre high voltage corona wires that get dirty.
White usually means that light is being blocked, and black usually means dirty coronas.
Don't know your technical level. if you need instructions
Let me know
Jan 16, 2011 | Canon CLC 4000 Copier
Printer panel shows "scanner failure, turn power off and back on to reset". I turn the power off and back on and get the same result. When the printer comes on in tries to initialize and makes a loud...
i have found the solution:
first of all, the problem is that the assy of the scanner can't find it's parking place. because it's to dirty.
the scanner moves slighty left when you start it up, then it scans for a black and white bar that's right next to the glass plate at the inside of it. This shall be to dirty to locate.
look at next link to clean the assy and glass plate from the inside:
http://dmsaudiocorp.deep-ice.com/psc2100.htm
make sure you clean the mirrors, the lens on the bottom of the assy and the glass plate from the inside.
remove all the dust you can find but be carefull it's very fragile.
i used some glass cleaning spray.
for me it worked very well!!
Jan 20, 2010 | HP PSC 2175 All-In-One InkJet Printer
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Dirty Glass on Lexmark X5100
suggest you bring your printer to the nearest authorised repair center and have them do the cleaning...it will save you cost
Mar 23, 2008 | Lexmark X5150 All-In-One InkJet Printer
hi,
thanks and regards
agnel
Dec 28, 2007 | HP Photosmart 2710 All-In-One InkJet...
Dirty glass
Sep 19, 2007 | Xerox WorkCenter PE120i All-In-One Laser...
HP PSC 2110 All-In-One InkJet Printer Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
