Question about HP DeskJet 1220c InkJet Printer
Troubles printing on photo paper
My printer doesn't print at all on photo paper. It can not load the paper. Is it the thickness of the paper? I use 210 g/m2 weight paper.
  • savio_perry Jul 26, 2008
    The printer wont pull any photo paper. However it does pull the normal plain paper. Can this printer print on photo paper???
    Genius:
  • 2,785 Answers
It might be check your printer manual for the exact paper weight
Posted on May 17, 2008
SOURCE:
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
[email protected]
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
HP Photosmart C4180 won't load photo paper
Remove the rear access cover and clean the black rubber rollers with alcohol.
Feb 16, 2009 | HP PhotoSmart C4180 All-in-One Color...
My printer wont print on photo paper.
Is it worked in past? Have you contact the HP for this problem? Since most of All-in-one printer do not possess better print facility, so it is difficult to use this one for photo print..
Photo paper is thick and may be motor not taking complete load of it. Check out with the roller moving firmly.
Oct 27, 2008 | HP DeskJet F380 All-In-One Printer
C5280
when you hit 'PRINT' the window that opens up to complete the job will have a button called 'preferences'. Check to see that the paper selected isn't photo paper. You will have you choice of paper type thickness and size.
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
234 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
