Question about Lexmark T632 Laser Printer
Manual paper handling
I would like to use the Manual feeder continously, like the job sent to the manual output should not stop feeding the paper after one sheet, they should get the second sheet in until the job finishes.
Is this possible?
  • 66 Answers
Should be able to. Change the default paper tray in printer to the manual tray.
Rgd
S88
Posted on Dec 19, 2008
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    What does load mp feeder letter mean? There is paper in the printer why is the printer not prinint
    load mp feeder means To load the Manual Paper Feeder
    You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
    You can change the settings to automatic paper feeding to get rid of this error.
    Aug 27, 2010 | Lexmark Optra T610 Laser Printer
    What does load mpf mean
    It does stand for Manual Paper Feed.
    On this printer, that's on the front of the unit, above the paper trays.
    Once your PC has sent a print job with the paper-select set to "Manual Paper Feed" the printer will not do anything until it's processed this job.
    The easiest way to do this is to put paper into the MPF and let it print, but at some point you're going to want to fix your PC so it doesn't send MPF print jobs anymore.
    To do this, open your Printer Properties and select the default paper tray instead of the Manual Feed.
    Sep 25, 2009 | Dell 3010cn Laser Printer
    EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
    Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
    Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
    IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
    Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
    Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
    When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
    SOLUTION(S): Reset the Sheet Feeder Gears
    If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
    alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
    home position, which may not be possible if the paper stop cam is not in the correct position.
    PROCEDURES
    1. Remove the sheet feeder from the unit.
    2. Remove the sheet feeder motor from the sheet feeder assembly.
    3. Remove the drive gear from its spindle.
    4. Realign the lifting tray gear and paper stop cam gear.
    5. Reinstall the drive gear and sheet feeder motor.
    6. Reattach the sheet feeder to the print unit.
    7. Reassemble the unit.
    Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
    Epson lq590
    check if your LQ590 is set for manual feedor continuous feed. There is a toggle switch somewhere near the rubber rollers,there are symbols that will indicate for continuous paper printing or manual, select manual printing. Also in your print window,select printer properties, select manual printing. Yourprinter might be set up for sheet feeder or continuous paper printing. hope this helped.
    Apr 23, 2008 | Epson LQ-590 Matrix Printer
    Print job will not print from the manually feed tray unless I select the Go button for it to process
    Table 3-7. Paper Handling Menu
    Item Values Explanation
    ENVELOPE FEEDER
    SIZE=COM10
    For supported paper sizes
    see page 1-12.
    This item appears only when the
    optional envelope feeder is installed.
    Set the value to correspond with the
    envelope size currently loaded in the
    envelope feeder.
    ENVELOPE FEEDER
    TYPE=PLAIN
    For supported paper types
    see page 1-12.
    envelope type currently loaded in the
    envelope feeder.
    TRAY 1 MODE=
    FIRST
    FIRST
    CASSETTE
    Determine how the printer will use
    Tray 1.
    FIRST: If paper is loaded in Tray 1,
    the printer will pull paper from that
    tray first.
    CASSETTE: A paper size must be
    assigned to Tray 1 using the
    TRAY 1 SIZE option (the next item
    in this menu when TRAY 1
    MODE=CASSETTE). This allows Tray 1
    to be used as a reserved tray.
    TRAY 1 SIZE=
    LETTER
    see page 1-12.
    This item appears only when TRAY 1
    MODE= CASSETTE. Set the value to
    correspond with the paper size
    currently
    Mar 12, 2008 | HP LaserJet 4350 Printer
    Feeder
    Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
    Oct 11, 2007 | Brother MFC-8220 Fax
    Sheet feeder isn't working
    which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
    Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Lexmark T632 Laser Printer Logo
    123 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
